Engine running hot.
Old Apr 18, 2001 | 10:38 PM
steven's Avatar
Engine running hot.
before i installed my 180* thermo in idol my car would move up just above 220* then the fan would kick on and cool it down, i installed a 180* thermo and it does the same thing, it won't kick on any cooler whats up with that, maybe my guage is broken, because when it was reading 220 i felt the top of the engine, which most of the time will get really hot, and it was still cooler, i could lay my head on it and it wouldn't hurt(i didn't, i'm not that stupid), but is it my gauge or whats up. thanks, later
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N fiter with custom Ram air[*]Flowmaster Exhaust w/ 3" tips[*]180* Thermostat[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]-----------[*]Best 1/4 ET as of Now[*]17.7110 @76.01www.geocities.com/my_92firebird
Old Apr 18, 2001 | 10:50 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
the fan is gonna come on at 227 degrees no matter what thermostat is in. if you let your car idle, the temp will keep rising until the fan kicks in. with a colder thermo, the temp is still gonna rise, just not quite as fast. hmmm, does that make sense?? i'm really bad at explaining things.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Apr 19, 2001 | 12:48 AM
HIX5000's Avatar
How hot does it run on the freeway?
Old Apr 19, 2001 | 05:01 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
When idling there's no way to keep the car's temp from rising. Air isn't flowing over the radiator unless A: the car is moving, or B: the fan is on. The fan doesn't kick on till the ECM tells it to. The EPROM in your ECM has that tempterature set internally, thus the only way to kick your fan on before 227 is to change that value in the EPROM (or manually wire the fan.. but that can be hazardous if you forget to turn it on/off). All the thermostat controls is when water actually flows through the radiator (with a 180 thermostat, when the water temperature inside the engine reaches 180 degrees, the thermostat should be at wide open, allowing alot of water to flow through the radiator).
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.
Audio Mods: Pioneer DEH-P3000, two 12" Optimus Pro Audio subs in hand-made enclosure each powered by a 260 watt Optimus amp. Working on shaving the box for weight.
My Homepage, with pics.
Old Apr 19, 2001 | 06:13 PM
steven's Avatar
thanks guys, i know understand, is there anything i can do that will make the fan come on sooner.thanks.
Old Apr 19, 2001 | 06:31 PM
HIX5000's Avatar
Try this article. I am using the derale relay mentioned in this article.
http://128.196.142.123/newdesign/tech/cool.shtml
[This message has been edited by HIX5000 (edited April 19, 2001).]
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
