Resetting the ECM...Help!
Old Apr 22, 2001 | 09:04 PM
87 Firebird's Avatar
I've tried desperately to reset my bloody ECM for the past week now. I've messed with timing, idle speeds and other **** but haven't been able to reset the SOB. I've pulled the ECM fuse for an hour. NOTHIN. I've pulled the Fuel Pump (FP) fuse for an hour. NOTHING. I've pulled both for many hours. NOTHING. I can't clear my bloody codes and therefore am not clearing my ECM. I want to be able to take advantage of my mods. Short of disconnecting the battery (I hate doing that!) What can I do on the thing??? Thanks!
Kevin-87 Firebird 2.8 A4
!Cat, !Maf, !Air Intake, K&N,
Best 0-60 10.26 seconds...for now
Old Apr 22, 2001 | 09:20 PM
Camaro_hunter_d's Avatar
PULL THE FUSE MARKED ECM....after 20 seconds replace it..
Old Apr 22, 2001 | 09:39 PM
As I stated in my first post, the ECM fuse did squat for me. I had it pulled for an hour. Nothing. Thank you, please try again :-)
Old Apr 22, 2001 | 10:09 PM
Belker's Avatar
Your radio presets aren't worth the frustration. Disconnect the battery.
AlexJH's Avatar
Engine: 5.7L V8
What's wrong with disconnecting the battery? That will work for sure.
Old Apr 22, 2001 | 10:49 PM
<sigh> guess there is no other way...thanks for all the help, guys. Where's my ratchet set?...
Old Apr 23, 2001 | 05:41 PM
20-psi's Avatar
If you ever read Chilton's, whenever you do anything with the car including changing the tires, you are suppose to disconnect the battery.
Pete
Old Apr 24, 2001 | 09:18 PM
well I have never had a problem clearing the codes by pulling the fuse. And if you follow chiltons to the tee they say to disconnect the battery to do anything. you kinda have to go by common sense with dissen the batt.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
mdtoren
Aug 23, 2015 12:52 PM
