How do i install roller-rockers???
Old May 3, 2001 | 11:10 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
whats the process??
what tools do i need??
what ones should i get?
i have a fairly good idea
just wanna make sure i'm correct
Old May 4, 2001 | 08:48 AM
KED85's Avatar
Kinda discovered this for my headds on my other cars.
IN MY INSTANCE, the parts are all there.
I am using Comp Cam Roller TIP rockers on small block chevy.
I put studs into the head, placed the rockeron , used supplied nut & rocker ball/.
For you, you must make sure it is the correct size for the shaft.
Small block chevy is a 3/8" shaft. Or 7/16".
What it is for these heads, not sure, my pair are at the machinist, so I cannot measure the rocker stud shaft for you. I see, it looks close in size, but, it's different.
You will need to remove intake set up (not the base) to remove the valve covers. Promise.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
