NEED HELP BIG TIME
Old May 21, 2011 | 06:57 PM
travisgold's Avatar
Car: 1984 Camaro Z28
NEED HELP BIG TIME
Camaro was running nice a few days ago started up 2 days ago it was running then it ran out of gas sputtered a bit so i turned it off put gas in her today she starts up and doesn;t even run for a second :O her rpms go straight to 0 and turn off please help! (the car is fuel injected) and 9 can hear the pump working
Old May 21, 2011 | 07:52 PM
ex-x-fire's Avatar
Re: NEED HELP BIG TIME
Get a tester & test the fuel pressure.
Old May 21, 2011 | 07:55 PM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
I wonder if the pump burned up from running dry.
Can that even happen?
Old May 21, 2011 | 08:44 PM
ice_man0617's Avatar
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
sounds like ign coil...do to the fact that it starts up and dies right away. i had that happen to me before. i would try that first. buy a new and just connect it to the coil plug and module connectors if it fires up stays on then there goes your problem
Old May 21, 2011 | 09:12 PM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
I just got mine running today. I had one fuel injector that was shorting out. It would start then run for about 2 seconds then die. If I touched the gas pedal after it started then it would die immediately. It wouldn't hurt to test your fuel injectors.
Old May 21, 2011 | 10:06 PM
travisgold's Avatar
I am guessing that it is the fuel injector i will take it too crappy tire to see if i can get it fixed
Old May 21, 2011 | 10:13 PM
travisgold's Avatar
@Sheriff420 That is exactly what mine does! Could you explain how to get at the injectors?
Old May 22, 2011 | 12:25 AM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
Remove:
-Throttle cables
-Throttle body from intake but leave the coolant hoses connected
-A/C compressor bracket to intake manifold
-EGR tube
-All the bolts for the upper part of the intake manifold
-All the vacuum lines connected to the upper part of the intake manifold
After that you can lift it off and test the injectors.
The best way to get the clips off the injectors wire harness without losing them is to grab it in the center with some needle nose pliers and pry one end off with a flathead screwdriver. You don't want to lose any of those.
Set your multimeter to ohms and put one probe on each prong on an injector, get the reading then move on to the next.
You're looking for each one to be over 12 ohms. Anything less and it needs to be replaced.
onefreakz
May 14, 2018 12:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
