hmm HelP!
Old May 7, 2001 | 05:04 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
hmm HelP!
changed the rockers this weekend..pulled the valve covers off (after 2 hrs of pulling crap off to get to em) and i put the new rockers on and set the valve lash. put everything back it starts and dies. you can hold it idling with your foot. Friend says it sounded like a vacuum leak. One of my emissions hoses broke in half when doing this and isnt connected. Could this be the thing thats causing it? Maybe something else? The rockers dont have any problems themselves, just most likely an error on my part when putting everything back in...(id rather see about those emissions hoses before pulling stuff back off...)
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 7, 2001 | 05:49 PM
Ovrclck350's Avatar
I'd say vacuum leak.
Old May 7, 2001 | 08:15 PM
KED85's Avatar
I agree.
Get 5/16" windshiled wiper hose to fix most of the cracked hoses.
Be prepared for more cracked hoses as you work on them.
Be real patient with them. They snap, really really easy. You should see my band aided hoses. Lots of 5/16" section!
Oh a good tip, before you slip the rubber over the plastic hose, slip a film of motor oil on the plastic, really helps the hoses go on easier.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited May 07, 2001).]
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Scania
Apr 20, 2002 06:04 AM
Z28Freakboy
Mar 13, 2002 02:16 PM
DrekkenX
Jan 22, 2002 09:49 PM
mudaholic
Pacific Northwest Region
Jan 19, 2002 06:09 PM
