Bent Crank
Old May 7, 2001 | 07:20 PM
Mach5's Avatar
Bent Crank
I know that cast iron can't bend because of the yeild point is the break point and there is no plastic modulus. The reason I ask is because the engine is leaking fluid out of the rear main seal but that is not the only thing. There is fluid leaking out of the front seal on the transmission. I have replaced the trans before twice so I am sure that the seal in the pump is good. The modulus of elsaticity of cast iron is the area under the curve of force vs deformation. THis would mean that cast Iron can't bend without returning to it's original position. Could my Harmonic damper be bad? Do I even have a cast crank? Has this happened to anyone before?
82 Firebird with a 2.8
87 Chevy K20 4x4 TBI pickup
71 Olds Cutlass S My ongoing project. Olds
350 with a th350
Old May 7, 2001 | 08:13 PM
KED85's Avatar
Certainly do not rule out the seal on the harmonic balancer is bad.
ANY balancer can eventually go bad
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 8, 2001 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I thought cast iron -could- bend! So you're saying the cast stuff would break instead of bend? I didn't know that.
As to fluid leaking from the front seal... how was the flange on the torque convertors? Could your TV cable be .. oh wait, '82.. that's the 200C three speed... doesn't that have a kickdown cable, and not a TV cable?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 8, 2001 | 03:09 PM
Mach5's Avatar
Cast Iron can bend. It just can't be permanently bent becasue then it would break
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
