When making a custom air intake.........
Old May 9, 2001 | 02:14 PM
Mike Harvey's Avatar
are there any certain materials that can give you that swirling air sucking sound better than another. For instance using actual mandrel bent exhaust pipe opposed to PVC piping from Home Depot.
What would work best?
- Mike Harvey -
1986 Firebird S/E
[This message has been edited by Mike Harvey (edited May 09, 2001).]
Old May 9, 2001 | 07:04 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Im actualy planing on redin my intake for the 3rd time i hate the nose mounted air itake you guys should feel how hot that thing gets consideig its sitting right on top of the radiator. When i do redo it im going to go to a exhaust shop and use exhast pipe i figure it cools down better then plastic and it wil be smoother inside
Old May 10, 2001 | 03:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used the mandrel-bent exhaust tubing (3" Hooker Header's J-bend, cut in half to make a tight 90 degree bend). I used the pipe instead of PVC because the PVC wasn't connecting up "gracefully" for me to the MAF and throttle body hose. The exhaust pipe isn't that thick and made my life easier. If only I painted it... it's a bit rusty
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 10, 2001 | 07:58 PM
Brian K's Avatar
http://geocities.com/overlift/Dcp02084.jpg
Go to that link and see my conical setup.... Very simple to make, sounds good and looks good. All you need is 1 17'' of straight PVC anda 3 1/2 inch conical filter. I am lucky cause I relocated my battery to the trunk, but my buddy put his where is Charcoal canister is and moved that to underneath of where it is.. He needed a longer section of PVC.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
kyle5647
Aug 15, 2015 11:56 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
