Anyone with Dynomax cat-back, question for ya..
Old May 11, 2001 | 11:45 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Let me know if this is true. I saw on another post that to install the I-pipe from Dynomax #17943 on a V6 car, you have to get a hanging bracket for a V8 car. Someone please let me know if I should hit the junk yard this weekend.
Thanks.
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
Daily driver:
2000 Pontiac Grand Am SE2
"Little girls play with ponies!"
www.geocities.com/camman86
Old May 11, 2001 | 12:22 PM
Ovrclck350's Avatar
I had NO installation problems whatsoever in mine. Everything that I needed was either included or used my old stuff (hangers, etc.).
Old May 11, 2001 | 12:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bet that was my post...
Yep, you need the right rear hanger. Some V6's have a right rear hanger that looks like a rubber oval with holes; the pipe is hung into the oval with a metal rod that goes "left to right".
V8's (with dual exhaust!) had a rectangle that fit against the rear upper frame rail, and didn't "hang down" like the rubber oval. The metal rod on the I-pipe slidese into the hanger "front-to-back". I found it easier to install the I-pipe first, then slide the hanger on, and finally, bolt the hanger to the right rear upper frame rail. It uses the same bolt holes & bolts as your V6 hanger.
So crawl under your car and check out the type of hanger you have... if you have the rubber oval, you need to replace it. I believe GM sells these new, too. I got two out of a junkyard for $5 total.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
billybob6110
Sep 24, 2016 09:50 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
midias
Aug 22, 2015 01:42 AM
redmaroz
Aug 16, 2015 11:40 PM
