Smog pump delete
Old May 29, 2011 | 02:26 PM
JohnnyCamaro91's Avatar
Car: 1991 Red RS T-Tops
Engine: 3.1 v6
Smog pump delete
I have a 91 RS 3.1 automatic, I've been reading around on the boards about a smog pump and ac delete. I read on one thread that most autos dont have smog pumps?? is this true? I'm assuming mine does because its the only component on my engine that I dont know what the heck it does. It is located on the lower passenger side of the engine. Anyways, the other day as i was driving it blew up on me. If it is a smog pump I dont want that government regulated crap on my car anyways. So my question is...asside from simply removing the unit what else needs to be done, ie. cap off lines, etc. And also the same for the ac unit. I looked through the threads and all I found was the one for the v8, any help would be great thanks.
Old May 29, 2011 | 07:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Smog pump delete
Smog pump has nothing to do with type of tranny - so yes, they are on all these cars.
This article assumes a V8 car, but I think the same applies to a V6 car - you can get an A/C delete pulley to remove the A/C, and just change the belt routing to remove the smog pump www.thirdgen.org/serpentine
Old May 29, 2011 | 08:47 PM
Engine: 3.1 v6
Do I have to get the delete pulley, or can I just remove them and use a shorter belt?
Old May 30, 2011 | 10:42 PM
Engine: 3.1 v6
Ok, I got a shorter belt today and put it on minus the smog pump. (still have not taken the pump out yet, as the belt fits fine with it still in) I was curious as to whether the a/c delete pulley is the same size as the a/c pulley.
Old May 31, 2011 | 07:47 AM
project89's Avatar
u dont need an ac delete pulley either just a shorter belt
Old May 31, 2011 | 08:19 AM
Engine: 3.1 v6
Ok, one more question how does the belt route once the a/c is out of the equation? Name:  100_1487.jpg
Should I go from the tensioner, under the water pump then over the power steering and down to the crank? or from the tensioner to the power steering then back over to the water pump? I am assuming there will not be enough clearance for the latter...
Old May 31, 2011 | 08:40 AM
project89's Avatar
the same way u have it except were it comes up the right side from the ps pump to the ac compressor u would go right from the ps pump to under the tensioner to over the alt pulley
thats how i did it on mine ,and also how its done on 2.8's without ac
Old May 31, 2011 | 09:04 AM
Engine: 3.1 v6
Might you have a picture? I'm thinking it might be better to go under the water pump then up and around the ps pump.
Old May 31, 2011 | 10:41 AM
Engine: 3.1 v6
Also, do you know what belt length you used. I went to murrays 4 times yesterday to get the right belt, lol.
Old May 31, 2011 | 11:18 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
What belt did you use for the current setup? I'd like to try that.
Old May 31, 2011 | 02:03 PM
Engine: 3.1 v6
Went to auto zone today and got the belt that fits with both the a/c and smog pump gone. Works great feels great. Now all I have to do is reduce weight, and get rid of the stupid things.
The belt in the current setup in the picture with the a/c still attached is 92 3/8"
Old Jun 8, 2011 | 04:44 PM
Engine: 3.1 v6
Originally Posted by jensen73110 What belt did you use for the current setup? I'd like to try that.
Hmm, this belt seemed to be ok at first, its flapping quite a bit now, dunno if its the heat or what, prolly would go a bit shorter tho
Old Sep 18, 2011 | 11:56 AM
dcbird's Avatar
Car: 89 formula firebird
Engine: modified 305 tpi
Transmission: 5 speed manual
Axle/Gears: 3.45 borg warner rear end
odd question, whats the smog pump do, and just getting a shorter belt is fine? nothing else?
Old Sep 18, 2011 | 08:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Smog, or AIR (air injection reaction) pump pumps air into the exhaust manifold and/or the catalytic converter to reduce emissions...
All you guys needed to do was to go to the parts guy and tell them you need a non-A/C, (or) non-AIR belt off of an 89 or earlier... Non-AIR is a 915K6 and without both is an 815K6... 91.5 and 81.5 inches long. Then, have the A/C evacuated and junk it along with the AIR pump and associated crap...
Old Oct 6, 2011 | 12:55 AM
thizzlamich's Avatar
Car: 88 Chev Camaro
Engine: L05 V8 from 93 Caprice Interceptor
Transmission: 4l60 Auto
Axle/Gears: Stock ones limited slip i believe
oOo sounds good, i'm going to have to do this, immediately, that damn pump has been dragging my engine down for some time, and all I had to do was delete it?lol yay
like dragging so much and making such a noise it was bringing down the amperage output of my alt., it almost sounds like the bearing is going out or something? there is a bearing in there right?
and I never use my ac anyways, but if I wanted to hook it back up for emissions or such, just leave it on right and keep the old belt?
Will it hurt Mpg or daily driveability at all?
Old Oct 6, 2011 | 02:03 AM
Brightwhitemaro's Avatar
Car: White 1991 RS & Black 1989 RS
Engine: 3.1L & 2.8L
Transmission: auto & T5
Axle/Gears: 3.23 & 3.42
So on a 89 with the smog pump it has a vaccum line and a sensor hooked to it what if their not hooked up what happens the check engine light a the comp goes to defualt loop?
Old Oct 6, 2011 | 10:19 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
How does this affect the catalytic converter if that AIR provision is blocked off but the cat is not gutted? I have my smog stuff removed but I installed a brand new non-AIR cat and blocked off the AIR provisions on the manifold and it seems to run 'ok'.. it heats up quicker I think and it doesn't idle quite as smooth as with the gutted cat.. Odd
Old Oct 6, 2011 | 10:34 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
I'm new at this, but from what I understand the o2 sensor is calibrated for the extra O2 thats being pumped in via the AIR system. with that gone, your emmisions will be seen as richer by the sensor and the computer will try to compensate for that. THis could cause the car to run a bit different. ideally, you want to get a new PROM burnt for your ECM.
looks like these guys can burn you a new chip for $65? http://www.gmtuners.com/eprom/index.htm That seems like a pretty awesome deal to me.... Got to look into that for myself.
Old Oct 6, 2011 | 01:04 PM
I had bought a chip already from tpiparts.net and then tuned the rest of the things I wanted to tune with Moates tuning software. It's easy to use but takes a bit to learn what needs to changed. I knew about the AIR and the O2 milivolts being 100mv lower but the chip I have accommodates for that. What I need to know is will my new catalytic converter survive without AIR, even though I have a proper tune (My BLM's are as close to 128 as they will get @ +- 126 to 130).. I would like to the affects on the actual catalytic converter, not the actual tune as it is already covered. Thanks in advance!
Old Oct 6, 2011 | 01:50 PM
Car: 88 Chev Camaro
So there would be more to it then just deleting it by getting a shorter belt then?
Old Oct 6, 2011 | 05:34 PM
Technically, yes.. Will most people be able to live without burning a new chip? Probably.. But if you want to do it right you need to adjust for the 0.100mv change when removing the smog stuff..
Old Oct 6, 2011 | 10:34 PM
Car: 88 Chev Camaro
got the 915k6 belt and tried to route it as in the pic and (91.5) inches long and for some reason it's way too long, by a couple inches, maybe I was routing it wrong, but I'm pretty sure I did it right, it was a little dark outside, guess Ill give it a go in the morn...
Old Jun 26, 2012 | 05:18 PM
Michael Cibelli's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Transmission: Whatever I stock I think 700r4
Axle/Gears: Stock
What belt number did you use ... I know this was posted a while ago but I got the 915k6 belt a said below but it was a little bit tooshort.
Old Jun 26, 2012 | 06:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You'll need to open the tensioner to its widest for a fresh belt. Yes, it will go. There are only 3 belts for the V6, smog and A/C (whatever part number that is as I've never had a smog pump), A/C without smog (915K6), and no A/C, no smog (815K6).
The way it's shown in the pic above is the factory routing without the AIR pump (except the factory doesn't leave it in place) for A/C cars, and I've posted other pics without both A/C and smog.
Old Jun 26, 2012 | 07:31 PM
Engine: 3.1
Axle/Gears: Stock
Yeah I did open it a wide as it could go I even tried to get a little pry bar in there and still nothing I have it routed the same way as in the picture
Old Jul 6, 2012 | 08:05 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Im going to the store tommrow to finally pick up a belt and get rid of the Air pulley. Now the parts cat. says 825k6 is for a 2.8L no AIR and no A/C It is 82.5 inches long.
Is that the correct belt because you have 815K6(81.5" long) listed on this thread. Just wana make sure before I go buy the belt tommorow. Thanks.
Old Jul 6, 2012 | 08:22 PM
Engine: 3.1
Axle/Gears: Stock
I needed a 93 inch belt for my 3.1 but the water pump spins backwards this is just without the air pump
Old Jul 6, 2012 | 08:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The 815K6 is what the guy at the parts store gave me when I asked for a non-A/C, non-AIR belt. Just like the other times I went in for an A/C, non-AIR belt and got the 915K6 (and I have replaced 2 of them, one because it was falling apart and the other because it was glazed and squealing). As it's listed in the parts catalogs.
Old Jul 6, 2012 | 08:49 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Mav heres what im looking at. I just wana make sure thats all.
http://shop.advanceautoparts.com/web...R%7CGRPBELTAMS_____
Ive got the 915k6 on it right now, was non A/C with the rest of the acc's intact.
Old Jul 7, 2012 | 06:22 AM
Engine: 3.1
Axle/Gears: Stock
It wa probably falling apart because it was rubbing on your power steering pump braket mine was
Old Jul 7, 2012 | 10:01 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Sorry mav. The info on that autoparts store was indeed wrong. I got a 825K6 like you said, this morning and it works great. More room where I needed it with the AIR gone.
Old Jul 11, 2012 | 08:59 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Ok quick question, how do you route the belt if you HAVE to keep the AC? Pics would be nice.
Years ago I found out my body's internal temp control thing in my body is defective, ( most likely genetic) but when I get in 70+° weather, my body temp shoots up to 102° and I start sweating worse than a hooker in church. That's why I need to keep the AC.
Old Jul 13, 2012 | 05:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
As in the pic above...
Old Feb 15, 2013 | 09:42 AM
RockShowTrader's Avatar
Car: 1988 GTA
Hey guys, I have an 88 5.7 GTA, keeping the AC but want to put the delete pulley in place of the smog/AIR pump. What do I do with the line coming from the pump? Can I leave everything else in place - for now - and just yank the pump out? I'm not interested in just bypassing it - I want to remove it.
Old Feb 21, 2013 | 02:06 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Does nayone know where I can get an A/C delete pully for my 92 3.1-my compessor is bad and I need a new belt. I'm going to keep the smog pump on for now, atleast till the car is too old for Ohio E-check.
Old Feb 21, 2013 | 02:41 PM
Car: 1988 GTA
http://www.hawksthirdgenparts.com/pr...te-Pulley.html
Old Feb 21, 2013 | 02:52 PM
2007xl50's Avatar
Engine: LB9/3.1
Originally Posted by RockShowTrader
Thanks, but if I can use a v8 delete pully then I can get one much cheaper at Summit Racing right down the road from me.
Old Feb 21, 2013 | 04:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They didn't use an A/C delete pulley. It was a shorter belt, just go to the auto supply store and ask for a belt for a '92 Camaro without A/C.
RBob.
Old Feb 22, 2013 | 07:35 AM
2007xl50's Avatar
Engine: LB9/3.1
RBob.
Do I have to move the PS pump or just route the belt for non-A/C???
Old Feb 22, 2013 | 09:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I doubt that GM would use a different bracket for the P/S pump on a non-A/C car. The belt routing diagram shows that the belt just doesn't go up over the A/C pulley. Let me see if I can find the diagram.
RBob.
Old Feb 22, 2013 | 09:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here it is... This is for a '90 - '92 f-body with the 3.1l engine.
RBob.
Old Feb 22, 2013 | 01:39 PM
  #42
2007xl50's Avatar
Engine: LB9/3.1
RBob.
Thanks for the routing, now i see the best way to do it. Ok when I get a belt I'm going to get a non-A/C belt and route it that way.
Old Nov 30, 2013 | 10:35 AM
  #43
chikenbag's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.1L V6
Hey everyone, just wanted to say that I used this thread to do my smog pump delete and my delete was completely successful. The belt routing shown in the picture above by johnny camaro IS the correct belt routing. The belt you MUST use for this if you still have A/C is part number 915k6. I got the belt from advance auto parts.
After installing the belt, there are 2 more things you must do-
1- plug the vacumm line going from the smog pump to the intake
2- plug the line going from the smog pump to the exhaust manifold
After that youre done! and I even noticed a slight increase in throttle response. Hopefully this helps some people who arent sure what needs to be done. This was performed on my 1992 camaro RS 3.1L auto
Old Nov 30, 2013 | 12:16 PM
  #44
Engine: 2.7L V6
Axle/Gears: 4.41
There is one other note:
When deleting the A/C, the mounting of the power steering pump needs to be changed. Remove the A/C compressor and all brackets (AFTER having the system discharged), and then remove the bolts from the front power steering pump bracket and the nuts and bolt from the rear bracket. Remove the rear bracket and put the pump back into place without it. Put the small bolt into the water pump hole and then rotate the PS pump bracket around until the upper large mounting hole at the top of the pump bracket ON THE RIGHT SIDE (A/C installation uses the hole on the left and DO NOT USE THE THREADED HOLE which is where the lower bolt for the A/C compressor bracket goes into) aligns with the bolt hole in the cylinder head. Put the bolt taken out of the original hole in here, put the belt on, and call it a day. The belt routing may look wrong due to the VERY limited clearance between the tensioner-to-PS pump and the wrapping over the water pump pulley, but it's the way GM did it at the factory (I have seen a factory 3.1 non-A/C car with this routing).
If you wish, you MAY be able to find a rear PS pump bracket for a non-A/C car, but it's going to be difficult... Or you can find a way to modify the stock rear bracket.
:edit: And you DO NOT have to do anything with the ECM when deleting the AIR pump. Our V6 engines LOVE running rich under acceleration and you won't throw any codes UNLESS you have an issue elsewhere.
Old Nov 30, 2013 | 11:59 PM
  #45
chikenbag's Avatar
Engine: 3.1L V6
Well said Maverick. Lots of good info. This should be the end all thread for anyone trying to delete their smog/air pump on a 3.1 liter. You are very correct, I didn't have to do a single thing with my ECM and no codes are popping up either. I didn't even remove the pump, its still in there (because I was being lazy lol)
Old Jan 12, 2014 | 12:59 AM
  #46
Nickmiceli7's Avatar
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
Question... If I gut my cat but leave everything hooked up as is will it throw off my o2 sensor?
Old Jan 12, 2014 | 12:45 PM
  #47
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
I vote make this a sticky
Old Jan 1, 2015 | 03:59 PM
  #48
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
im looking to keep my a/c but eliminate my smog pump. Everything is disconnected, just only have the pump only mounted.... Ideas? 3.1L V6 manual trans.
Old Mar 10, 2015 | 06:53 PM
  #49
IRZ28's Avatar
Car: IRZ28
Engine: 5.3
Transmission: 4L60e
Axle/Gears: 10bolt/4.10
So I deleted my smog pump ! What's size belt would I need for my 89 TPI
Old Aug 12, 2015 | 08:33 PM
  #50
Derrickum's Avatar
Car: 1989 Camaro
Engine: 2.8
Transmission: 5 Speed Manual
Ive got some questions for people with v6. I bought my 89 rs and it wasnt all there. The ac was gone so I got a belt to route around it. My questions are this.
1. Where the intake is, one hose goes to the brake booster and the other goes where ?
2. Smog pump, its currently hooked up with the belt but there is a small black fitting for a vacuum hose on the unit. What plugs there and where do it plug to?
3. There is a small black cylinder like sensor. It has 3 fittings for vacuum hoses. Ome goes to the egr one goes to the tb or charcoal canister(not sure) and the other isnt plugged up. Just the fitting for the vacuum hose. What goes here?? Please help.
