engine doesnt want to start right away?
Old Jun 1, 2011 | 12:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iv had this problem for awhile and it bothers me, when i first get in my car i get in, turn the ignition on so the pump can prime and pump alittle then i turn the key, but my problem is that sometimes the engine just sits and cranks for a few seconds and it bothers me. is there any reason it would do this? might add that sometimes it doesnt do it, sometimes it does so its a hit and miss for me. help!!
Old Jun 1, 2011 | 02:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: engine doesnt want to start right away?
Check the fuel pressure. I don't just mean stick the gauge on it and look at the pressure when the pump is done priming, I mean let the gauge sit on there for half an hour and then come back to it. If the system loses more than 2 PSI in half an hour, you have a problem. Either the fuel injectors, fuel pressure regulator (I hope those screws aren't too messed up for you), or the check valve in the fuel pump (or the lines between the pump and the engine) are leaking.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
