Hypertech Power Chip with 180 thermo???
Old Jun 4, 2001 | 01:46 AM
AntiVTEC's Avatar
I know that the hypertech chip is supposed to work in conjunction with a 160 thermo... but would a 180 work with it? The 160 seems like its wasting gas and looses a little power and i wanna switch over. What would happen if i put a 180 with the chip in? Thanks!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"I'm out to seek those pesky VTEC boys!" (don't get me wrong, I'm asian myself! hehe)
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Jun 4, 2001 | 05:30 AM
Ovrclck350's Avatar
My Jet CAME with a 180, so I believe a 180 would work with a Hypertech. If I remember correctly, Glen told me that all the commercial chips except for FastChip mainly just turn down the fan turn-on temperature and advance the timing a lil at WOT.
I would go with a 180. I picked up 5MPG.
Old Jun 4, 2001 | 07:08 AM
Brian K's Avatar
180 will work fine and for most people it workls the best.. I would though recommend fastchip.com if you can return you Hypertech Chip.
Old Jun 4, 2001 | 10:14 AM
Red88RS's Avatar
i pulled my 160 and put in a 180 with my hypertech chip, 'cause it ran too rough and the mileage went waaaay down. now it runs much better.
Old Jun 4, 2001 | 11:11 AM
AntiVTEC's Avatar
Tight!! gas milage is exactly what i need... imma go get one today! thanks fellas.
Old Jun 5, 2001 | 04:30 PM
AntiVTEC's Avatar
Got a little problem fellas... where do i get a 180 thermo? thanks.
Old Jun 5, 2001 | 08:06 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Isn't a 180 the stock thermostat?
I just recently bought a JET chip,
was going to get the 160 stat.
They say it gives "consistent engine cooling and increased horsepower by reducing engine temperature and a precise metering of water throughout the engine" is that just a bunch of crap?
Old Jun 6, 2001 | 12:06 AM
AntiVTEC's Avatar
Stock temp is 195. lots of people say 160 is too cold and the motor wont run in closed loop operation, which wastes alot of gas. Well, i've run into the problem and am gonna switch over to 180 and see whats up. About that smooth coolant flow crap, the chip doesnt control when the coolant flows through the motor, the thermo does. Payce.
deracer
Apr 11, 2016 12:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
sailtexas186548
Aug 24, 2015 10:11 PM
NWAsonoma
Aug 18, 2015 05:45 PM
