weird sound
Old Jun 10, 2011 | 07:47 PM
rick121's Avatar
Car: 91 Camaro RS
Engine: 3.1 liter
Axle/Gears: positrac off an 83 T/A
weird sound
My 91 3.1 liter started making this sound the other day. it sounds like a serpentine belt noise but it only happens when i make a left turn and usually quits if i turn right. however now it will sometimes continue even after turning right. I cannot tell where the noise is coming from. anyone else have this problem?
Old Jun 10, 2011 | 08:01 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: weird sound
Squeel? Some times sounds like your doing a front-wheel-drive burn out?
Check power steering fluid & belt tension
Old Jun 12, 2011 | 02:01 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: weird sound
yeah, sounds like PS to me too.
Old Jun 12, 2011 | 10:05 PM
rick121's Avatar
Car: 91 Camaro RS
Engine: 3.1 liter
Re: weird sound
the pump itself or could the steering gear do that? I figured maybe the pump but the fluid is clean and the pulley turns smooth and straight, and it still powers the turn so I'm not positive
Old Jun 13, 2011 | 12:07 AM
Engine: 3.8, 3.4
Re: weird sound
Couldn't say without hearing it in person, I would know the sound, but its hard to describe, generally if its a belt or pulley it will be a kind of high pitched squeeling, if its a bearing in an accessory its usually high pitched sound like metal grating on metal, if its the steering box, kind of sounds like gears grinding or something with like an electric dinge to it, like the noise hydraulics make sort of, or something, best I can describe it.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
