I Need Traction!!
Old Jun 23, 2001 | 01:12 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
I Need Traction!!
was messing around with a civic SI this morning..and at one stop i was holding the clutch, reving it at 1600. When i let out the clutch, i did it very slow, but i was spinning my drive tire and i was all over the road.. The most obvious is the SLP posi which im going to order tomorrow or hopefully today, then im going to try out a spohn torque arm. Any other ideas? What about wider rear tires for increased grip? Whats the largest i can get on the 15x7 rear wheels? Im not going to swap rims, so im going to fit the largest on the rims i have. TIA
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, and Ram Air 2 hood
"I'd rather run last in a full out race, than to not have run at all"
Old Jun 23, 2001 | 02:03 PM
KED85's Avatar
IF ya can find one, cheap (you may be able to) Corvette rims from the 70's are 8" wide, same bolt pattern, too.
I have paid $5 for one wheel.
Long Beach swap meet is the place to go!
2nd Sunday every month!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 23, 2001 | 09:17 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Keep in mind that a little wheelspin is actually a GOOD thing. If you have none at all, you'll bog more off the line. Seeing as how the 60 degrees' have so little torque as it is, be careful you don't make it hook up too good!!
And this is not a slight against V6s...I've seen LT1s with trac-links and slicks bog off the line and end up with higher 1/4 mile times!!
Jason E
'89 Camaro RS
Medium Grey Metallic
2.8, A4, T-tops, 91k miles
'97 Z28 w/30th Anniversary package
LT1, M6, t-tops
White with orange stripes, killer system, 42k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Jun 23, 2001 | 09:20 PM
Yea, know the bog..when i first got my car with the auto, went to LACR..bogged BAD...ran again got mid 17's..
1989 Firebird
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
Old Jun 23, 2001 | 09:22 PM
Hey, anyone know if i can see some helping with traction from subframe connectors? I can see how i think they would, anyone else?
1989 Firebird
Coming for my v6:
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
