MSD 6AL
Old Jun 28, 2001 | 07:39 PM
PimpRide92's Avatar
MSD 6AL
I plan on getting this soon. I already have a Accel Elec. Super Coil. Can someone give me some steps on how to install this. I want to do it myself to learn as much as i can about my car. Thanks
1992 RS 3.1L
Rebuilt Tranny W/
Trans-Go Shift Kit
B&M MegaShifter
ES Trans Mount
Dual Snorkel Intake
W/ K&N'S
Flowmaster Exhaust
Accel 8.8mm Wires, Cap/Rotor And Elec. Coil
1 12" - JL W6 (Loud)
Eclipse 2-Channel Amp
Sony Head Unit
Window Tint 20%
'92 Z28 Wheels
Kill's:
80's Stang 4-Cyl, A few Ricers, Ford Tempo(Weak)
'91 OR '92 Z28(Dont Ask Me How) All On A Mesh Up Tranny! 4th Gen 3.4, Cutlas Ciera 3.8
Old Jun 28, 2001 | 08:58 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
yeah, i wanna know 2!!!!
Slayer of the following:
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Old Jun 29, 2001 | 12:41 AM
AntiVTEC's Avatar
The instructions are included right in the box. Make sure you use the plug style connectors they include to make it alot easier. Dont use the wiring harness if it comes with it. Good place to mount the thing is in the passenger corner of the engine bay. Final note, follow the wiring diagram for "GM DUAL CONNECTOR COIL". Good luck! payce.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"I'm out to seek those pesky VTEC boys!" (don't get me wrong, I'm asian myself! hehe)
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Jun 29, 2001 | 08:49 AM
KED85's Avatar
Is that Accel the unit that has two wires from it & is screwed onto the firewall?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 29, 2001 | 11:12 AM
PimpRide92's Avatar
Yes. It has a dual connecter cable that goes to factory harness then to + & - terminals on the coil
1992 RS 3.1L
Rebuilt Tranny W/
Trans-Go Shift Kit
B&M MegaShifter
ES Trans Mount
Dual Snorkel Intake
W/ K&N'S
Flowmaster Exhaust
Sony Head Unit
Window Tint 20%
'92 Z28 Wheels
Kill's:
Old Jul 2, 2001 | 07:51 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Hey AntiVTEC, did you get better gas mileage after you installed the 6al? did u "feel" the power that was added??
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Jul 2, 2001 | 11:07 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
6a and 6al are totally the same except for the rev limiter..both have the same power output etc. ive looked at some other competitors, and crane has a digital one that puts out nearly double the msd and draws the same..
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 3, 2001 | 11:27 AM
AntiVTEC's Avatar
The gas milage got boosted alot, maybe 3-4 mpg. But then that was offset when I installed my chip, hehe.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Old Jul 3, 2001 | 03:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's easy to hook up, but hard to find a spot for. I mounted my 6AL where my coolant overflow bottle was. It's mounted so you read the label from the driver's side fender. I made a bracket to go between the lower part of the box to the strut tower, and the upper part of the 6AL just bolts to the strut tower.
I then put a tiny aftermarket coolant overflow bottle where my stock air filter used to be.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
