3.1 coolant leak, help please
Old Jul 3, 2011 | 01:38 PM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
i have a 1992 camaro rs w/ 3.1L v6 engine. I don't know if this item is the issue in my picture but it would appear so. Anyone tell me what this is and if its possible that my coolant is coming from here. Thanks
Attached Thumbnails 3.1 coolant leak, help please-leak1.png   3.1 coolant leak, help please-leak2.png   3.1 coolant leak, help please-leak3.png
Old Jul 3, 2011 | 02:20 PM
Guest
Guest
Posts: n/a
Re: 3.1 coolant leak, help please
Yes.
Do you want to repair it correctly, or just stop the leak for a few months?
If the latter, then just drain a couple gallons of coolant from the system, then clean that up really good, then use a lot of JB Kwik and goop it all the way around. Let it sit overnight, then refill and enjoy.
Old Jul 3, 2011 | 02:27 PM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
What is it that is leaking? and i would rather fix it correctly
Old Jul 3, 2011 | 03:22 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
looks like the gasket between the timing cover and block or water pump to timing cover. It is not hard to repair. My old Firebird use to do it. Had to replace the gasket twice in three years. Just make sure you have a good set of Torx sockets. I believe they are in the water pump and timing cover on those engines. Its been awhile since I drove a V6.
Old Jul 3, 2011 | 07:40 PM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
it is the item i circled, the heater inlet fitting. when i squeeze the hose i can see fluids leak out. during the removal of this part it broke.... the treads are still in the block. is there any good(easy) ways to remove this? Thanks for all your help
Old Jul 3, 2011 | 08:00 PM
Ouch! My lil bro's old 3.1 did that! I remember he had to get an easy out to get the coupling out.
Old Jul 3, 2011 | 08:21 PM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
well what was his easy out?
Old Jul 3, 2011 | 09:18 PM
LOL! thats the name of the tool "easy out". it is like a drill bit but the blades are backwards. Just go to any autoparts store and tell them you need one. I think they can loan it too you. Also, Sears sells them.
Old Jun 22, 2017 | 09:34 AM
aycaramba's Avatar
Car: '1991 Pontiac Firebird
Engine: LH0 - V6 3.1
Transmission: TH700R4 automatic
Hey Guys
I've got the same leaking issue on my '1990 3.1 V6 and I would like to fix it.
What kind of gasket is there in place? Can I replace it like using a new O-ring rubber gasket?
I hope my english is not too bad...
Thanks.
ayCaramba
Old Jun 22, 2017 | 02:13 PM
Drew's Avatar
It's a quick disconnect that GM used back then. They used them on the fullsize pickups too. They frequently cause problems. So much so that any autoparts store worth it's salt will have the fitting and the extractor needed to remove the old broken fitting, on the shelf.
The "fix" is to replace the quick disconnect with a heater hose barb fitting, and a few inches of heater hose with a couple clamps.
Old Jun 25, 2017 | 07:51 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Had the same leak. Typical 3.1 leak.I Put like a whole bottle of some Krazy glue. Still holding up. NO BS
Old Jun 25, 2017 | 08:52 PM
NoEmissions84TA's Avatar
Oh, that's what it is. Had to replace mine on my pickup. OEM made of Chinesium. I found a better made replacement at Advance Auto.
Old Jun 25, 2017 | 08:54 PM
Originally Posted by aycaramba
Hey Guys
Thanks.
ayCaramba
It is 1/2" male pipe thread, I believe.
Here is the one my truck needed: https://shop.advanceautoparts.com/p/...hose+connector
Old Jun 25, 2017 | 11:04 PM
aycaramba's Avatar
That's exaclty the one I was looking for! Thanks.
Old Jun 25, 2017 | 11:47 PM
Drew's Avatar
Replacing the fitting with a new quick disconnect will work if the mating end of the hard pipe is in good enough condition to seal. It's not terrible unusual for the pipe to rust. That's why I suggest using a barbed fitting, heater hose, and a couple clamps. They will seal, and it won't fail again in the life of the car.
Old Jun 26, 2017 | 12:01 AM
Good point and the other option.
Old Jun 26, 2017 | 02:33 AM
aycaramba's Avatar
Can you send me a link or a number which I can use for example on rockauto.com to order that part? It's hard to get stuff like that in europe with imperial threads. Thanks.
That would definitely fix the issue for at least 20 years.
Old Jun 26, 2017 | 07:11 PM
Search for pipe fitting union. I did some searching and came up with a few other options. I don't know your exact sizes of pipe thread and hose size, so you will have to make the choice. Looking at your picture, it seems that a 90 degree fitting might work better, but I don't know if you have the clearance to thread it in. Good luck.
https://www.rockauto.com/en/tools/ho...ting+union,286
https://www.rockauto.com/en/moreinfo...622798&jsn=975
http://www.oreillyauto.com/site/c/se...=1&results=All
https://www.rockauto.com/en/parts/ac...cumulator,6972
http://www.ebay.com/itm/Brass-90-Deg...-/222094183718
http://paceperformance.com/i-5147283...-4-length.html
http://www.oreillyauto.com/site/c/de...0886&ppt=C0108
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
