Trouble Starting
Old Jul 8, 2011 | 07:56 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Transmission: Auto 4
Trouble Starting
I started my car today to check the water levels after I installed a new thermostat and new plugs, spark plug wires, distributor cap, and rotary button... now my car shut off after idleing about 25 min and it slowly started idling lower and lower til it died. Now when i try to start it it wont start. It sounds like a sound you would hear when you hold your hand over the carb of a motor to cut out the air... but i know the sound is from the exhaust pipe...
Old Jul 9, 2011 | 11:08 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Trouble Starting
You may want to check your cap and rotor again. Sometimes they don't always go in straight and get messed up on the inside. I had this happen to me once before. Also check to see if the vacuum lines that go in to the back of the intake plenum are still hooked up as they can be easy to accidentally knock off when replacing the cap and rotor.
Old Jul 9, 2011 | 01:16 PM
89Camaro88's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
Well I checked for codes today and 3 came up-
23. Low temperature at manifold air temperature sensor OR Throttle position sensor error
32. Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
42. Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
What do these mean like what do I need to do to fix these problems...
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
