A/C Compressor Vibrates
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Hey guys, i noticed the other day my a/c comp vibrates a LOT at idle when its on only, when you rev the engine, the vibration goes away. What does this mean? Is it going bad? It still works but once the engine speed is slowed down, the air doesnt stay cold, and when the engine speed goes up, it gets cold again. TIA
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Car: 1986 Firebird
Engine: 2.8 V6
How's the belt? Could it be loose/worn/slipping/etc?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 1986 Firebird
Engine: 2.8 V6
Any mounting bolts loose? Is the engine out of tune (and struggling when the a/c's on at idle)?
actually it does struggle a little when at idle, but then the engine speed rises to comensate (i guess cause of the computer)
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I thought I'd mention that I'm having an almost identical problem. I own a 1991 Camaro RS and whenever I idle and turn the AC on, I get a massive amount of vibration that runs through the car...shakes my mirrors, vibrates through the floor, the shifter..everything. WHen I go into Neutral, the vibration lessens, and when I turn the a/c off or switch to vents, the vibration completely goes away. When I begin to accelerate, the car performs normally...it's only at idle speed that I get the vibration. Also, when the AC is on, the engine hesitates to accelerate...you press the pedal and the car lurches forward for a second before jerking a little and accelerating normally. Checked the belts and they're all fine.. And my engine isn't losing any RPMs to the compressor..I checked.
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
I had the same problem on my v6 2.8. Check all your mounting bolts! Mine ended up being loose.
It rattled so much that it cracked the mounting bracket. Power steering pump is also attached to this bracket. Talk about a pain in the *** to fix! I had to take it to a mechanic because you need a special tool to remove the power steering pump.
Hope this helps.
Hope this helps.
Car: 1986 Firebird
Engine: 2.8 V6
Are you talking about the power steering pulley? My '86 2.8's p/s pump unbolts from that bracket, no special tools necessary... in fact, I plan to eliminate the a/c+p/s combo bracket- I yanked my a/c out.
Resurrecting this post, do I have to set the timing with the a/c on? How many bolts are there to tighten on the a/c compressor?
2012sergen11
Oct 13, 2015 07:38 PM
roysatikas
Sep 22, 2015 08:15 PM
