Tranny swap won't start
Old Aug 5, 2001 | 01:39 PM
Little E's Avatar
This week i did the tranny swap thing and now it won't start. Wont click over, but have power. Do you need to unhook the park switch or does that affect it, if so how do i change. Would i have something to do with not hooking up a neutral safety switch. Would like to get it running soon, Please help
Old Aug 5, 2001 | 09:31 PM
86Chicken's Avatar
If the starter will not turn then the neutral switch is the best place to start.
The purple and yellow wires that went to the shifter on the auto MUST be connected for the car to start. To do it right, there should be a connector under the dash with purple and yellow wires on it from the factory in case your car was a manual. This connector should be hooked up to a switch on the clutch pedal so that the car cannot be started w/o pushing in the clutch pedal. If these are hooked up then ignore the wires going to the auto shifter connector.
I am not sure if the connector under the dash only works if there is a manual ECM in or not.
BTW, have you put in the proper ECM chip for a manual or are just going to wing it? The car will be OK with the auto chip in but it will have a strange idle.
Hope this helps!
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Old Aug 5, 2001 | 10:46 PM
Little E's Avatar
Can i order an aftermarket chip for it? is this the same as the oem chip with mods or just a plug in thing.
Old Aug 6, 2001 | 10:22 AM
86Chicken's Avatar
I bought the manual chip from GM. I don't know anything about aftermarket chips, if you can specify auto or stick then I think all is good. If the chip is designed for an auto the computer will make the car "hunt" for idle when the clutch pedal is in while driving. No big deal just a little annoying.
I also noticed a change in brake pedal feel between the auto and manual chips. With the auto chip the pedal was hard but with the manual chip, the pedal is kinda spongy. Must have somehing to do with the amount of vacuum to the power brake booster.
Dale
Old Aug 7, 2001 | 10:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just changing the chip did that? I thought it would've been the slave cylinder running off vacuum, but not the chip... strange, eh?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
camaro11j
Sep 19, 2018 08:49 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
hokis
Aug 9, 2015 03:57 PM
drathaar907
Aug 6, 2015 04:20 PM
