floating rear end...
Old Aug 21, 2001 | 12:50 AM
nothingssafe's Avatar
Car: 86 TA
k what causes it and what can i do on a budget to fix it. you know the one i'm talking about, where you take a turn and your rear end catches up a second later...
1988 Camaro
2.8 with T5
K&N
Soon to be CAI or Ram Air...
http://www.nothingssafe.com
Old Aug 21, 2001 | 02:40 AM
AntiVTEC's Avatar
simple... get a posi rear end. Get one out of a junk car closest to your year. direct swap in and can be done right in your garage.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Old Aug 21, 2001 | 04:18 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if I remember right also by putting stiffer springs in the rear or a bigger anti-roll bar in the front will help the issue a bit also
but the LSD will be one of the better options
better grip for a drag launch and also when going into a turn will give the power to the outside wheel with the weight rather then the inside one
ICQ 4116192
AIM RXspeed87
Got rotary?
hon-duhs breakfast of champs
gotta love the camaro
Old Aug 21, 2001 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do you mean oversteer (rear of the car kicks out on a turn) or understeer (front end "plows", you turn the wheel but the car seems to keep going straight)?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 21, 2001 | 02:01 PM
AntiVTEC's Avatar
what are you tryin to say tomp?
Old Aug 21, 2001 | 02:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm wondering what he means by "take a turn and your rear end catches up a second later"- oversteer, or understeer.
Old Aug 21, 2001 | 08:33 PM
Car: 86 TA
its like it catches up with me. im not talking aobut losing traction and makin the back end break lose or rip the tires. someone told me to just buy new bushings and this could solve the problem...
1988 Camaro
2.8 with T5
K&N
Old Aug 22, 2001 | 01:19 AM
88-RSport's Avatar
I think I know what you mean, is it like when you also swirve a little and then you feel the back end shift? Cause I noticed that too. Right after I got my tires. I used to have pirrelli R 15 50 p215 Z rated, then got daytona R15 60 P 225 not Z rated And noticed it started doing that. I'm guessing cause of the height of the tires, the walls are a bit taller and don;t have much stability on turns I think that's what started causing the swaying
Old Aug 22, 2001 | 01:44 AM
Car: 86 TA
i have stock tire sizes on there...
1988 Camaro
2.8 with T5
K&N
Old Aug 22, 2001 | 03:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Try the energy suspension polyurethane torque arm mount. I threw one on when I was putting my rebuilt 700r4 transmission into my car. It really firmed the butt of the car up around turns; it eliminated that "wobble" I used to feel. It was a definate seat-of-the-pants improvement, and only ran me $30. If you check out http://www.energysuspension.com, you can find the application data for the part. They make a few; GM changed the torque arm over the years.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Irocohio
Aug 12, 2015 08:03 AM
