3.1 Liter Bad gas Mileage
Old Aug 13, 2011 | 12:15 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
Ok here is my issue:
1991 V6 5 speed, motor just recently rebuilt, new timing chain, new head gaskets and heads rebuilt. New injectors, new tune up. Just installed headers, EGR blocked off. Gas Mileage is approx 10-11 mpg and my V8 gets 18-20. What can I do???????????
Any help is appreciated.
Old Aug 13, 2011 | 01:19 PM
ex-x-fire's Avatar
Re: 3.1 Liter Bad gas Mileage
Verify the ecm grounds, usually on the back of the head(s), are clean & tight.
Make sure the ignition timing is set & advances when you rev it. Timing really effects intake vacuum. Low vacuum will cause it to run rich (when you have a map sensor).
The coolant temp sensor has a big impact on running rich, do a ohm test on the sensor at different temp. Google GM CTS ohm values for the temp/ohm rates.
Check fuel pressure & bleed down rate, may have a bad regulator or leaky injectors.
Old Aug 13, 2011 | 03:37 PM
joecool108's Avatar
Engine: V8, V8, V6
I also have added a 3 wire O2 sensor, because of where the pacesetter headers has it relocated. The distributor is new including the pickup coil and module.
Old Sep 14, 2011 | 09:15 PM
joecool108's Avatar
Engine: V8, V8, V6
Ive replaced the Fuel pump, filter, injectors and plugs and still only get 11 MPG.. HELP!!!!!
Old Sep 15, 2011 | 06:24 AM
ex-x-fire's Avatar
Did you check the stuff in my post?
Old Sep 15, 2011 | 12:01 PM
wager420's Avatar
Car: Pontiac FIREBIRD
Engine: 3.8L
do u know if the 3.1's have 2 cts? 1 temp sensor and 1 sending unit? i assume 1 right? i have similar issues, iv replaced the ctp but still got a a code for cts. i hope its not a defective cts, but that code still comes out. i got two codes. map sensor and cts. map iv replaced as well.
Old Feb 24, 2012 | 02:33 PM
davila0115's Avatar
Car: 92 Camaro RS
Engine: 3.1l V6 .40 Over
Did you ever figure this out JoeCool108?
chazman
Aug 28, 2018 03:25 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
Bradsaundry
Aug 12, 2015 12:34 AM
