New info for you modded guys (3.1 firebird, etc)
Old Aug 28, 2001 | 11:41 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
stock injectors for us are 15lbs! im running the svo 21lbs... TRY LOOKING INTO THIS! I emailed some fiero guys running the same mods as us and they are running the 21lb injectors as well but have 305tpi afpr and have upped the pressure! Im looking into an afpr soon as well. Just some FYI
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
[This message has been edited by Graeme'sFirebird (edited August 28, 2001).]
Old Aug 29, 2001 | 11:42 AM
AntiVTEC's Avatar
Did you see and improvement out of those? Man, I've always been lookin for an AFPR!!! How'd did you get it in and what part # did you use!?!? What about the injectors... where'd you get them from? Thanks man!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Old Aug 29, 2001 | 12:31 PM
Injectors are bosch SVO 21lb for a 305 tpi same thing for the afpr its for a 305tpi
See my car Here!
Old Aug 29, 2001 | 04:14 PM
AntiVTEC's Avatar
Any mods needed for the AFPR? Was it direct replacement? Howd you set it! THANKS!
Old Aug 29, 2001 | 05:23 PM
Havent put in QUITE yet.. im looking to do a lot of porting and the larger TB before i put it in. was 70 dollars
See my car Here!
Old Aug 29, 2001 | 06:03 PM
Drew's Avatar
I've done a few homemade AFPR's now, the Lb9, L98, LH0 and the 2.8 all use the same fuel pressure regulator.
Old Aug 29, 2001 | 08:14 PM
Camaro_hunter_d's Avatar
Damn gramae I did not think they were THAT low!. Good grief thats why nothing really show any good improvement when we do something!. NO FREGGIN FUEL!
Old Aug 29, 2001 | 08:15 PM
HOLD on you are talking about the 2.8/3.1 right. I know the 305 TBI only has like 14-15 PSI running the fuel system.
Old Aug 29, 2001 | 10:06 PM
AntiVTEC's Avatar
Would 21 lbs/hr be over kill for out little v6's? Well, it might be more suitable for you Graeme, but what about for us that just how external mods?
Old Aug 29, 2001 | 10:25 PM
3.1 firebird's Avatar
good info grammy. Its good to know we do have somekoptions when it comes to fuel pressure.
Old Aug 29, 2001 | 11:03 PM
<font face="Verdana, Arial" size="2">Originally posted by AntiVTEC:
Would 21 lbs/hr be over kill for out little v6's? Well, it might be more suitable for you Graeme, but what about for us that just how external mods?</font>
the poundage really does not matter because the pulse is controlled by the comp.(this goes to turbo info so bear with it) thats why a 875cc or roughly 45Lb injector can get 30 plus MPG with low boost pressures but as the boost goes up and the intake leans the pulse is longer to compensate.
ok thats a little confusing. The poudage makes no difference as long as there is enough fuel delivered to keep the mix normal and not lean. The amount of fuel is controlled by a pulse thats sent by the comp. When we go to WOT(snaping the throttle/flooring it from dead stop) we get VERY lean, thats why no go. Upping the poundage richens that up a little and then the fuel is maintained throughout the rpm range and load conditions.
Old Aug 30, 2001 | 10:46 AM
AntiVTEC's Avatar
Yea cuz I remember someone telling me on this board that getting bigger injectors is like putting a quad barrel carb on a stock 305. See what I'm saying? But if the injectors will work on our cars, what kind of improvments should we see? (Sorry for all the questions, it's just that I haven't done anything to my car for awhile cuz I've been looking for another mod that'll get me somemore power.) Thanks!
Old Aug 30, 2001 | 11:03 AM
Drew's Avatar
I was running 3.4L injectors on my 3.1 and it was so rich the car wouldn't idle, much less make any power. For reference my 3.1 has a cat delete pipe, and modded airbox, nothing else. I got alot more power when I went back to stock 3.1 injectors even though they're in bad shape.
Old Aug 30, 2001 | 12:09 PM
KED85's Avatar
When I did the swap, I used the 1995 issued 3.4 injctors. They have a shower pattern, not a pintle style.
NO DOWN SIDE AT ALL & I PASSED CA EMISSION PERFECLY.
My story.
No problems.
I can't offer an answer for your instance, Drew.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 30, 2001 | 12:53 PM
(3.4 injectors are 19lbs)
700r4--&gt;t5 w/ram clutch
See my car Here!
Old Aug 30, 2001 | 01:30 PM
I think Drew used Lumina Z34 injectors. I know the FWD has some head/intake differences, maybe this is why they didnt work well.
Old Aug 30, 2001 | 03:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The "Multec" was the other style, instead of our pintle injectors; and I think that's what all the front wheel drive cars got. I didn't know a Multec injector would fit in place of our Bosch pintle-style... did you have to mod the fuel rail, Karl?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 30, 2001 | 05:29 PM
Drew's Avatar
The injectors I used were from a Z34. They're the same style injector as the stock 3.1 injectors. The earlier 2.8 injectors are a little different but they're interchangable. I might give the 3.4 injectors another try as my 3.1 injectors are crapped, but I'd rather sell them. They're practically new, a buddy of mine had em in his Z34 for a very short time.
Old Aug 30, 2001 | 07:16 PM
KED85's Avatar
In my instance, they fit perfectly.
NO adaptation necessay, just went right in.
Fit is identical to the 1985 style. Mine from a 1995 F-Body car, the ones I got on my 95 3.4 F-Body engine. I was suggested to upgrade to those during my asking for this engine swap.
Chat Soon,
KED85
Karl
Old Aug 31, 2001 | 03:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could always zip 'em off to Rich Jensen, at http://www.cruzinperformance.com for a flowtesting and cleaning. I did that with my spare set of 2.8 injectors; it made one helluva difference in the car.
Hey; could that be a reason why improvements are felt with these higher-flow injectors- simply because they're clean?
jhawkeye
May 25, 2022 06:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
the_nikfive
Aug 11, 2015 02:46 AM
