How to make round fit in an oval?
Old Aug 31, 2001 | 07:02 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
was thinking about my cold air today, and i looked and at the TB connection hose, the end to connect to the factory air box is oval, can i possibly make it work or no way?
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Aug 31, 2001 | 10:36 PM
KED85's Avatar
Yea, ya need a heat gun.
I used one to "fix"/mod my stock box top lid.
For the first time ever, I may have to clean that filter!!!I got more air flowing in!!!!.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 1, 2001 | 12:04 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Just trying to help anyway I can...is the end facing the stock airbox a hard or soft plastic (if you cup your hands around it, and press, does it bend alot?). If it's the same as it was on my tpi job, the oval end has a hose clamp on it. This keeps the plastic from being any bigger and keeps its shape. Simply take the clamp off (of course go buy a new one that's circular from the store) and put the circular one on the plastic tubing. Use some wd40 or something slick to slide the pipe (pvc or metal) into the plastic tubing. VERY tight fit, but take that clamp and tighten it. If you use pvc, the pvc might melt back to the oval shape...but if you use metal it should hold its shape. Hope this helps.
Old Sep 2, 2001 | 02:49 AM
Camaro_hunter_d's Avatar
well a soft malet for metal working one side at a time and test fitting after every series of massages... PVC easy a painters heat gun 12 bucks. another way to get the metal to form is with a tail pipe expander with several of the slides removed.
Old Sep 5, 2001 | 02:48 PM
squirrelybird's Avatar
I might be talking about something different, but if not.....I just used a rubber coupler with hose clamps on each end which you can pick up at any home depot speed shop for a few bucks. One end can connect to the oval TB while the other end can remain round to connect with whatever else you have.
Old Sep 5, 2001 | 07:12 PM
<font face="Verdana, Arial" size="2">Originally posted by squirrelybird:
I might be talking about something different, but if not.....I just used a rubber coupler with hose clamps on each end which you can pick up at any home depot speed shop for a few bucks. One end can connect to the oval TB while the other end can remain round to connect with whatever else you have.</font>
Yeah I saw those type of clamps at lowes the other day... they are used for PVC I believe. Their like 3 inches wide or somrthin like that.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
kyle5647
Aug 15, 2015 11:56 PM
matthew911
Aug 12, 2015 09:38 AM
z28addict8490
Aug 7, 2015 08:48 PM
