Is there a V6 firebird STB
Old Aug 19, 2011 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
couldnt find anything useful for the birds...
are there any over the counter STB's that will fit the firebirds with the 2.8/3.1? Not looking to buy on, just curious if there is on, and how they get over the upper manifold. Its a bit tight.
Old Aug 19, 2011 | 07:36 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Is there a V6 firebird STB
its really not any tighter than the v8s.... i have one from i believe edlebrock. its the three point brace
Old Aug 19, 2011 | 07:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it is tighter in the firebirds since the hood slopes down more than on the camaros. I have a carb/tbi edelbrock one laying around, and its not even close, hits everything, and it doesnt seem that i can get a piece of 1"or 1.25" tubing over the engine anywhere and still be able to close the hood, unless im doing it wrong....
Old Aug 19, 2011 | 08:19 PM
Pocket's Avatar
Car: 91 Trans Am
All the V6 birds I can remember working with had bellows imprints in the hood insulation. That little engine sure is tall
Fab your own STB, its not that hard
Old Aug 19, 2011 | 08:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats the plan,
Not looking to buy one
but i was curious if and how i can get a bar across the engine, hence the question. And you are right, there are imprints in the hood insulation for the bellows and the manifold, it all fits pretty snug. I have a idea though.
Old Aug 19, 2011 | 08:33 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The TPI STB won't fit? It is really tight over the TPI plenum & I don't see the fit problem any different than the V6 engine.
Old Aug 19, 2011 | 08:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it may, but the v6 manifold is a lot wider, so that may be an issue. I dont have one handy to test though...
Old Aug 19, 2011 | 08:47 PM
Car: GTA
I know the BMR on is a flat plate over the plenum for the thinner section & the UMI one has the plenum area notched for the plenum to fit up in to. Dunno if the V6 is wider or taller
http://www.bmrsuspension.com/index.c...&productid=376
http://www.umiperformance.com/catalo...kqi6o4krkil2u6
Old Aug 21, 2011 | 12:15 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
I have a hotchkis on mine and I adjusted it to fit. That was with the stock hood on.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
