89 V6 2.8L Camaro Power Loss
Old Sep 12, 2001 | 01:32 AM
NicholasP's Avatar
Every now and then when i stomp on the throttle to have some fun, my Camaro starts going and then just drops right off, when i pump the gas peadal in nutral she comes back to life but for the life of me i cant figure out why. a little help would be much appreciated.
Nick
Old Sep 12, 2001 | 09:57 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Is it Carb or FI
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Sep 12, 2001 | 10:28 AM
NicholasP's Avatar
Multi Port Fuel Injection
Old Sep 12, 2001 | 11:24 AM
AntiVTEC's Avatar
does it do it as certain temps? cool or hot? Does it happen when you apply the gas suddenly or when you apply it smoothly? And specific RPM?
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 12, 2001 | 12:18 PM
NicholasP's Avatar
only when hot and when i stomp on it and only in 1st gear its really screwed up and its about 3500-4000 rpm area when it just dies on me , im thinking vacume hose, but not sure, any other ideas are welcome, tks.
Old Sep 12, 2001 | 12:44 PM
AntiVTEC's Avatar
Definatly check those vacuum hoses. They can work wonders I'll tell you. I had a bad vac hose and I could barely pull 105 MPH. After I fixed one tube, I got back my 130 MPH top speed! (Well, I have that 85 MPH speedo and I had it wrapped back around to 30.)
Old Sep 12, 2001 | 12:53 PM
NicholasP's Avatar
tks for the help i will run 2 lordco and change em and see if that helps.
thanks for yer help
Nick
Old Sep 13, 2001 | 02:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It could also be the timing. Over-advanced timing at low RPM would make the car act badly from a stop.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 14, 2001 | 06:13 PM
NicholasP's Avatar
how do you change the timeing on a Fuel injected car?
Old Sep 17, 2001 | 08:19 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
<font face="Verdana, Arial" size="2">Originally posted by NicholasP:
how do you change the timeing on a Fuel injected car?</font>
The same way you would any car, except for one thing. Instead of pulling the vaccume line off the distrubutor, you disconnect the EST (Electroning Spark Timing) wire. This is usually located on the passanger side by the computer. I think it is brown/tan or tan/black. Then time it just like you would on a good ol' carborated engine.
Old Sep 17, 2001 | 10:24 AM
NicholasP's Avatar
tks!
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
