Is it bad to have rust under the gas cap?
Old Sep 17, 2001 | 10:43 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
From what the subject says does anyone have an answer? Does anyone else have this under the gas cap?
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Old Sep 17, 2001 | 11:28 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Any rust any where needs to be stopped as FAST AS POSSIBLE, it's called "car cancer", Go to a body shop or do it yourself, clean up all rust and prime and paint it fast.
Old Sep 18, 2001 | 08:26 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Rust is a natural process so let it be its great for removing all kinds of parts, lol
Gas rots a car body pretty quick, but where i live they put so much salt on the roads it doesn;t matter, its going to rust, Rust Sucks, and you should get it looked at because rust on the gas cap is the most common place to see it.
Old Sep 18, 2001 | 09:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Under the gas cap... as in, inside the tank? Or do you mean under the filler door?
Look to http://www.por15.com for the ultimate in rust-stopping paint. I used it for my 3.73/posi/disc axle swap, and on the T/A rear sway bar, and it worked great! The super starter kit's only $20.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 18, 2001 | 11:36 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Like when I unscrew the gas cap, there is rust on the thread of the gas cap and the place you put the gas in. Is this bad?
Old Sep 19, 2001 | 10:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, inside the fill nozzle? It's not -that- bad... chances are, that rust is pretty "dry", since it's under the cap. The thing to watch for is to try not to wash the rust out of the filler neck and into your gas tank, where the rust will clog the filter.
You could take a rag (not a paper towel!), moisten it, and rub it over the rust; see if it picks up any loose particles. Don't use a paper towel because you don't want a piece of towel falling into your tank. It'd be hard to do, since there's that little flap blocking the gas tank, but why chance the risk? Sounds like it's fine, though.
1992 Trans Am
May 10, 2023 07:19 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
