No oil pressure
Old Sep 25, 2001 | 06:05 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
No oil pressure
I was driving today and i noticed my oil pressure was low around 20 psi then i hit a stop light and it goes into the red and the needle would drop down pop outta the red back into the red and so on... Is my oil pump bad or is the sending unit or the guage it self going bad what should i do.
Old Sep 25, 2001 | 06:19 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
check the connection at the pressure sender at the oil filter. Replace the sender too.. if not check the gauge... could be the oil pump is going out.
Time has come... i bought a nova.. so its time to sell the firebird.
http://cgi.ebay.com/ebaymotors/aw-cg...item=595764164
I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 25, 2001 | 06:23 PM
FAST RS's Avatar
I have a feeling it isnt the oil pump because when i put the key to the on position normaly the needle would be at zero now it goes past 80 psi and maxes out so i dono whats up with it.. how much is a oil pressure sending unit? and how hard is it to do
Old Sep 25, 2001 | 06:34 PM
oil pressure sending unit is like 8 bucks, all you do is unclip the electrical connector and unscrew it, then put some hi-temp silicone on the threads of the new one and screw it in.
See my car Here!
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
