*** Attention OneTireFire ***
Old Sep 27, 2001 | 12:40 PM
87 Firebird's Avatar
In another post, you mentioned that you boosted your fuel pressure to 50 PSI. How did you manage that??? I'd love to know! TIA
Kevin Harlow
87 Firebird - LB8 A4
!Cat, !MAF (sometimes), !TB Coolant, Cutout, K&N, Modified Air Intake, Tru-Cool Tranny Cooler,
Air Assist Springs, Ported intake!, Ported + Polished TB Blade
Corvette Servo coming soon...
HPH C.A.I. kit coming soon...
DIY White Face Gauges - www3.mb.sympatico.ca/~bharlow/
Old Sep 27, 2001 | 01:41 PM
OneTireFire's Avatar
Here ya go....it's kinda long
Step one: Disconnect negative battery cable
Step Two: Remove aircleaner assembly
Step Three: Remove gas cap to relieve system fuel pressure
Step four: Disconnect injectors and get the injector plugs out of the way aswell as the aircleaner stud (just turn it to face away from the injector pod)
Step Five: Remove the Eight (8) Torx screws on the top of the injector pod. Take note of the positioning of the 3 longer screws.
Step Six: With the screws removed from the top of the injector pod lift away the "roof" of the injector pod. Some fuel will leak out and be very carefull with the gasket so it does not tear or any debris fall into the path of fuel. The fuel pressure regulator is attached to it. It is the gold iridite "cup" looking object.
Take note of the tab sticking out of the fuel pressure regulator cup. This represents the range of adjustment. The higher the tab is the more compressed the spring is equalling more fuel pressure. You'll see what I mean later. GM seems to have no set fuel pressure as those who have performed this mod have all had varying fuel pressure settings from the factory.
Step seven: Now you will have to dissasemble the fuel pressure regulator. There are four torx screws holding the cup to the injector pod "roof". Slowly and evenly loosen the screws while maintaining firm pressure on the cup because it holds a spring under some tension. remove screws evenly while maintaining pressure. Once all 4 screws are removed carefully lift away cup. the spring will release tension and you may set it aside along with the injector pod roof.
Step eight: Take note of the fuel pressure regulators function. A small platform with a tab that sticks out the side of the cup rides on a threaded shaft. The higher the platform in the cup the more compressed the spring and the more fuel pressure is acheived.
Step nine: Now to make that threaded shaft movable and furthermore, adjustable easily. You will have noticed the shaft does not move. Flip the cup over and take note of the pressed in cap in the hole on the bottom of the cup. This must be drilled out. Its pressed in there quite well, and is not easy just to pull out. I and others have had to completely drill out the cap.
Be carefull so as to not exert too much pressure as it is possible to knock out the metal peice that is pressed into the cup on the bottom in which the cap sits
Step Ten: Now that you have drilled out the cap you will find that the screw and platform inside the cup are not only movable but removable from the cup. By turning the screw counter clockwise you raise the platform thus raising fuel pressure. You can raise the platform to a higher pressure and put it back together at this point but that takes away some of the adjustability to it.
Step Eleven: Now if you have a dremel with a cutoff disk this is much easier though you might be able to accomplish this with a hacksaw. Cut a slot in the head of the screw so that a small flathead screwdriver can turn the screw.
Step Twelve: Reassemble with a slightly higher fuel pressure setting. This time turn the cup around so that the tab does not face inwards and is not visible but faced out and is visible so that you can view the amount that the platform is raised. If you dont understand what I mean, just skip that.
Step Thirteen: Put injector pod "roof" back on top of injector pod. Be sure to snug down all screws to prevent leaks of fuel. REconnect Injectors, Put gas cap back on and reconnect negative battery cable.
Step fourteen: Start car with aircleaner assembly removed from car and watch for leaks from the top of the injector pod. No leaks? great! If you have a leak be sure you tightened the screws. You might need a new gasket. Most autoparts stores sell gasket material to make one or you can buy one from GM. You might also be able to find a gasoline compatible silicon sealer. BE CAREFULL THOUGH you CAN clog your injectors.
Step Fifteen: Put aircleaner back on and refer to TUNING WITH YOUR O2 SENSOR & DIGITAL VOLT METER in the tech section to be sure you have the right pressure! To re-adjust pressure its going to take you to remove the 8 screws on the injector pod roof again and just use a small screwdriver counter clockwise in the little slot you made to raise fuel pressure and clockwise to decrease it.
As for exact psi....your gonnna have to refer 2 a fuel pressure guage
I had my friend test mine, and he said it was 50 psi, but i'm not exactly sure about that.
I do no that the adjustments I made helped alot.
Keep in mind that without enough cfm of air an increase in fuel pressure, wont be beneficial to your performance.
Bad A$$ Boys Drive Bad A$$ Toys
deracer
Apr 11, 2016 12:04 AM
drumstixer
Sep 29, 2015 03:02 PM
gta90
Sep 15, 2015 04:00 PM
Todd84Z
Sep 4, 2015 08:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
