I was reading this post in here and noticed
Old Oct 1, 2001 | 06:12 PM
Monkie's Avatar
Most of you guys were saying that your car would idle at about 600rpms at an average and mine when I start it shoots up to 20,000rpms and drops down to about 1,200rpms at the least. What does this say? Is there something wrong?
Old Oct 1, 2001 | 06:17 PM
XxMoLexX's Avatar
20,000 RPMS?!!!!! u got some kinda F1 motor under the hood?... hehe... im sure u meant 2,000
maybe the idle needs an adjustment... and check the vac hose by the master cylinder... i had a small leak there once and it caused the idle to run screwy.... kind of an off chance... but jus maybe... other than that i havent a clue
White 91 3.1 RS.
T-Tops
12" Sony XS-l1235 Bass tube powered by MTX 2120 amp. Kenwood 8015 Head unit
16" ROH Rims
Firestone Firehawks
ES Urethane Tranny Mount
Old Oct 1, 2001 | 06:21 PM
c-5invalid's Avatar
mine does that also... if i havent been in it for over an hour when i start it it goes up to 2,000 then 15000 and as it get a little warm it will go down to like 800
Old Oct 1, 2001 | 06:36 PM
Monkie's Avatar
And if the car isn't warm you have to be a good driver with a manual or it will jump, drop, try to stall. Pretty much if it is cold to get it moving smoothly you have to feather the clutch until you get moving and then going into second you have to do the same. Anyways about the high idle....anyone know if I should be worried??????
Old Oct 1, 2001 | 08:29 PM
86Chicken's Avatar
When I start mine in the morning it idles around 1500 until it warms up then drops to about 800.
I would start looking for vacuum leaks. They are a prime cause for high idle problems.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
Great cars aren't bought, they are built
Old Oct 1, 2001 | 08:59 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The specs for my car at least call for 600 RPM in an automatic and 800 RPM in a standard... I usually get about 900 RPM, I should adjust the carb.
Edit: If you idle high, it may be a lot of things... idle screws and vacuum leaks are the major culprits. Vacuum leaks will usually apear erratic though.
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb + Intake - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, AIWA bargain basement (from Sears of course) CD player, Eight-ball shift ****
Check out my ride here - My $1300 Toy
"IT'S SNOWING! TO THE HIGH SCHOOL PARKING LOT!" - The Mustang and Firebird face off in the dead of winter.
[This message has been edited by ChillPhatCat (edited October 01, 2001).]
Old Oct 1, 2001 | 10:14 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Sounds completely normal to me...
Old Oct 2, 2001 | 07:55 AM
SAEspinz80's Avatar
yea sounds normal to me too....it was 40* this morning in CT (woohoo) and yea the rpms have always shot up tp 2000 settled at 1200 and then once the car is warm a nice 6-800 mark....
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I. (KNN-RE-0810)
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil (8226)
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back (27121)
- 2.5" Hooker Elite Stainless Extension Tips (31503)
- GTS Blackouts (stickers removed - #GT034)
- TB Bypass
KILLS = Dodge Daytona, 2000 Toyota 4 Runner 4WD,
1999ish Explorer XLT, "older" Jeep Cherokee, 68ish Mustang (died completely when the light went green )
LOSSES = 300zx (took me in 2nd )
"The racing dice added 5hp...I SWEAR!"
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
bamaboy0323
Aug 15, 2015 07:20 AM
