Leaking antifreeze
Old Oct 7, 2001 | 09:43 AM
Bizzy's Avatar
Leaking antifreeze
Hi. Remember me? Anyways, my camaro is leaking antifreeze from behind the a/c pulley. I was wunderin how to stop the atifreeze from going to the a/c. If there's a way to bypass it. Its pouring out like a river. It doesn't work anyway. Also my tranny doesn't seem like its shifting right. It makes a hissing sound when it shifts. What could cause this and how can i fix it?
Dying 1984 Black 2.8L LC1 Camaro SC
mods: 160* thermostat, CAI, stock V8 2 1/2" dual exhaust, Bosch Platinum +4, 8mm Accel wires, GTS taillight blackouts, Cool Blue headlights
Old Oct 7, 2001 | 01:33 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Coolant doesn't go to the A/C at all. Where exactly is it leaking from?? Is it near the water pump??
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Oct 7, 2001 | 02:20 PM
OneTireFire's Avatar
It sounds like ya might have a blown water pump.
Bad A$$ Boys Drive Bad A$$ Toys
Old Oct 7, 2001 | 04:10 PM
Bizzy's Avatar
Its coming from the bottom pulley on the left side of the engine. Is the water pump a b*tch to replace?
Old Oct 7, 2001 | 10:55 PM
Bizzy's Avatar
I looked at it again and the coolant is coming from the center pulley on the bottom of the engine, under the fan.
Old Oct 7, 2001 | 11:34 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Most likely its the water pump. The hardest part is getting all the accessories outta the way. Oh and cleaning the gasket surfaces before putting the new one in is also a pain. Otherwise, its a straightforward job. I think KED would recommend you get a new timing chain if you haven't replaced it recently. But I wouldn't want to go that far.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Oct 8, 2001 | 12:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you look closer, you might see coolant dripping out of the "weep holes" on the water pump. These are small holes located right behind the pulley. When they go, it means the seal in the pump is shot.
Be careful scraping the old pump gasket off the timing chain cover. The chain cover is aluminum; don't gouge the soft aluminum too deeply!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 8, 2001 | 07:42 PM
Camaro_hunter_d's Avatar
do not forget about the aluminum fitting for the heater hose too. those break alot. cheap aluminum. replacement is steel and costs 7-8 bucks from dealer. This thing is right under the throttle body and drips over the water pump.
Old Oct 11, 2001 | 09:08 PM
mm4tt's Avatar
same problem! EXACTLY with my car, 82 firebird se
from that bottom pully. its the water pump
pull the pully and **** off i guess and replace gasket.. pump.. and the transmission thing,
is it where like when ur driving around a certian speed, 35-40mph, maybe 1900-2000rpms and it hums or something, mine is doing that too... i would replace ur fluid... not sure what it is tho...
-matt
Old Oct 12, 2001 | 11:37 PM
Bizzy's Avatar
Thanks guys. I'm pretty sure that's what it is. And thats exactly the problem with the tranny.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
