heads/cam
Old Oct 11, 2001 | 11:48 PM
one tweaked 3.1L's Avatar
heads/cam
hey guys what could i expect from a head and cam setup, cam would be 264/274 and 423/.423 the heads would be mildly ported and polish. i want to get an idea because i will be doing this soon
1992 Camaro RS.
mods:flowmaster,catco high flow cat,k&n, MSD coil,bosh 4+ and 8mm wires,Redline engine and gear oil, Jet chips stg 2, single piece driveshaft.
Old Oct 12, 2001 | 10:25 AM
Kyle F's Avatar
In a V6 without a custom chip for it, about 20 hp and a **** poor idle.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 12, 2001 | 12:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't know about that; that's the specs for the CompuCam 2030. If you port/polish the heads, you might need to get an AFPR to bump the fuel pressure up a few PSI. Your heads would be flowing more air, but your car won't know that, and will supply fuel as it always had.
Then again, if you're doing a mild port job, you might not need the AFPR. A guy I knew had his heads ported (4th gen 3.8 v6), and ran slower at the track. He found out he was running really lean- he got an AFPR, and it fixed the a/f ratio, and he felt the power come back.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 12, 2001 | 06:35 PM
Kyle F's Avatar
I think the Series 2 3.8 had swirl port head to promote a faster more complete burn(not sure).
Some porters will remove this protusion in the head casting, and well it will flow more on a bench test the head will not performa as well. Those with LS1's have learned the hard way about this.
High Tech Pontiac did a article on this about a year ago. It was pretty interesting.
Past Thirdgen:
Old Oct 12, 2001 | 08:41 PM
is that a bad cam? and what is afpr? i was also considering some headers (heard 3.4 worked just some bending alittle) and i probably put a custom chip too. this is goin to be the first major project for my car
Old Oct 12, 2001 | 09:58 PM
Camaro_hunter_d's Avatar
<font face="Verdana, Arial" size="2">Originally posted by one tweaked 3.1L:
is that a bad cam? and what is afpr? i was also considering some headers (heard 3.4 worked just some bending alittle) and i probably put a custom chip too. this is goin to be the first major project for my car</font>
AFPR Adjustable Fuel Pressure Regulator. Headers... good luck, yes 3.4 will work with bending... still good luck. With the price of a chip buy chip burning equip and make your own. I have the BIN for the 3.1 if you want it. I can email it to you.
Old Oct 12, 2001 | 11:21 PM
i don't really now much about burning chips, is that difficult to do?
Old Oct 12, 2001 | 11:27 PM
also if i do this "project" would a higher stall converter help?
Old Oct 13, 2001 | 02:46 PM
Jaren Bon Jovi's Avatar
If you get the cam make sure you get the correct instructions from the factory. When I got mine installed, the factory gave different directions. The cam made me lose 4 tenths. A 16.12 to a 16.49 Make sure you have the correct measurements for the valve springs also. I have a very expensive repair that eventually will get fixed, but Crane wont back it up. Its not worth it. The best thing to do is ditch the V6 and pick up a Formula.
Old Oct 13, 2001 | 10:52 PM
thanks for the warning, i evantually want to do this because i can't really afford to buy a v8 (TPI,Lt1) i am going to school (FSU) riht now and the v8 swap is out of my reach,so i am going to work wih what i got righ now
Old Oct 14, 2001 | 11:24 AM
i don't really now much about burning chips, is that difficult to do?</font>
Well chips are not hard to do. Just plug into the programer equipment and load the modified BIN. As I sadi I have the BIN for the 3.1 If you want it. You can get into it and look around if you want. Change the rev/speed limiter, change the fuel/spark map, change the "shift" light on the manual cars(kinda cool)
86White_T/A305
Aug 17, 2015 12:16 AM
ll-84camaro-ll
Jan 24, 2006 01:00 PM
M1A1TankerTom
Northern California
29
Dec 27, 2005 09:06 PM
CrazyHawaiian
Dec 19, 2005 06:59 PM
OUTATIME GTA
Jun 21, 2005 08:26 PM
