Don't Forget
Old Oct 30, 2001 | 06:37 AM
Brian K's Avatar
Don't Forget
It is always about power, but many are forgetting suspension. LCA's torque arm, and panhard rod will improve your 1/4 times too... It will also help you corner better. Also there are polyurethane bushings, drop spindles, vented disc brakes and stainless steel brake lines....Do these before you go after a chipp or pulleys or if you can't do a cam and roller rockers... Life is not always a straight line...
Old Oct 30, 2001 | 08:34 AM
Ovrclck350's Avatar
Why not? I live my life one 1/4 mile at a time....j/k
Old Oct 30, 2001 | 03:49 PM
WaynesRS's Avatar
How does suspension mods help in your 1/4 time ? I kinda get and ideau how it would , but I wanna see if your thinking the same thing I am , or If im wrong . .Its hard to explain what im thinkin lol .
Wayne
Old Oct 30, 2001 | 05:22 PM
Brian K's Avatar
Even though we have these 2.8's we still loose traction. Toss some slicks on your car run the 1/4 then go back to street tires. You will see a slight gain.
SO besides wheel hop, slip whatever you want to call it we do loose some traction racing like all cars. Suspension mods reduce that loss and transfer the power to the ground better and faster thus improving your time...
Old Oct 30, 2001 | 08:25 PM
Ovrclck350's Avatar
Suspension helps for weight transfer, body flex, and keeping the car PLANTED (no wheel hop) which all helps your 1/4 mile.
Old Oct 31, 2001 | 12:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can even put an air bag in the right rear spring. By inflating it (you'd have to mess with the correct PSI), you'd enable the car to launch straighter than usual. It'd cut down on "squat".
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 1, 2001 | 09:06 AM
Brian K's Avatar
Okay can we say GP on:
LCA's
Torque Arms
ECT.....
Actually I bought a Ford Explorer and got rid of my truck and I can get all sorts of cool things like a TB Spacer, FIPK Kit, Larger Sway bars and it is a 4.0 liter...
I still have the 86 CAMARO 2.8
backtothe80s
Sep 5, 2015 12:39 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
cougar20th
Aug 27, 2015 08:04 AM
