idle problem
Old Sep 26, 2011 | 11:21 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
idle problem
so I'm having a problem with my 87 2.8, the car stalls whenever I pull up to stop lightsand things for more than about 15 seconds. It also frequently stalls out when I put it in reverse. Now I've replaced the idle air controller and hooked it up to a scanner and it wasn't throwing any codes. Any ideas? This problem is getting really annoying...
Old Sep 26, 2011 | 11:38 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: idle problem
When's the last time a tune up was done?
Have you checked the fuel pressure?
Old Sep 27, 2011 | 12:00 AM
Re: idle problem
It got a tune up about 7k miles ago. The scanner said fuel pressure was good but how do you check?
Old Sep 27, 2011 | 02:14 AM
Firechickenv6's Avatar
Car: 1991 Firebird
Engine: 5.7L V8 TPI
Axle/Gears: 10-bolt posi w/drums
Re: idle problem
Hey, it might be possible that you have to relearn the idle. I've had to do it once or twice on my 3.1 (replaced IAC/battery). Some say it isn't needed, some say it helps. Either way, it couldn't hurt so here's the link I've found:
https://www.thirdgen.org/forums/v6/1...ac#post1121031
Old Sep 27, 2011 | 01:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: idle problem
I don't know how many times now I've said this... THERE IS NO IDLE RELEARN ON A 2.8, PERIOD. Except FWD vehicles after 1986 and maybe 1989 F-bodies (don't know about the 89 ECM or the S10 after 1990).
OP, check for vacuum leaks. If the vacuum hoses are original, they're probably degraded to powder. Replace them all after checking with fingers to see if they have deteriorated. And get a fuel pressure gauge. There is NO WAY a scanner would know the fuel pressure at the fuel rail.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
