Gunk in the intake ????
Old Nov 6, 2001 | 06:59 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
I noticed today when I took all the intake hoseing off the there is alot of gunk grease and grime in the inner sides of the intake and on the back of the butterfly. How would I go about doing a through cleaning of the intake without messing anything up is there a guide with pictures?
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
97 Firebird 16X8" Rims
Old Nov 6, 2001 | 07:13 PM
Xenodrgn's Avatar
Go to an automotive store and buy some stuff called "something something for fuel injected engines" I forget how they word it exactly on the bottle. You'll know when you see it. It'll be in a can like WD-40 and Brakleen. Just MAKE SURE it says 'for fuel injected engines' somewhere on the can. Do not use carb cleaner! We have some kinda of protective substance on our TB and plenums that the carb cleaner takes right off, hence the 'made for FI engines' specific cleaner.
Old Nov 6, 2001 | 07:31 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Yep, get some FI cleaner, I had this same stuff its dark black, and its all over the inside of the intake. Well mine was caused cause my engine is getting old, and has alot of Blow-by.
Make sure you get FI cleaner though the wrong Carb Cleaner can cause more harm than its worth....
Old Nov 6, 2001 | 07:33 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
Go to an automotive store and buy some stuff called "something something for fuel injected engines" I forget how they word it exactly on the bottle. You'll know when you see it. It'll be in a can like WD-40 and Brakleen. Just MAKE SURE it says 'for fuel injected engines' somewhere on the can. Do not use carb cleaner! We have some kinda of protective substance on our TB and plenums that the carb cleaner takes right off, hence the 'made for FI engines' specific cleaner.</font>
Oh yeah, and to clean it... take off the TB, and upper plenum and just spray it down. Paper towel and wipe, spray some more, wipe some more... ect... Could do the middle and lower portion as well, but the fuel rail will have to come off, and you're talking about at least a day long project, possible extending throughout the weekend if you go that far...
You'll probably need to pick up a gasket set for the TB and plenum... shouldn't cost -too- much. I suppose you could reuse the gaskets but don't yell at me if you get vaccuum leaks...
One more thing. While everything is off and once clean, you could also do some porting and polishing. Even simple gasket matching will help. Smooth everything out and make the transitions into the parts as clean as possible. The real work thats needed on our engines in on the exhaust side of things, so there is no need to get too excessive.
Old Nov 6, 2001 | 09:01 PM
87_Camaro's Avatar
hey xeno, what do ya mean "simple gasket matching" what is that? what do ya do?
Old Nov 6, 2001 | 09:15 PM
breathment's Avatar
well i kinda did the same thing last weekend, took of my intake, took it to car wash, high pressure washed it and then let it soak in soapy water overnight, getting ALOT of carbon off, then i ported it, and gasket matching is when u port the intake on both sides of the gasket, which means the gasket it actualy bigger, and becomes a restriction since u took away material on both sides where the gasket will go, so the gasket gets in the way, so u cut it so its size matches the size of the port openings.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 7, 2001 | 10:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I actually cut my own gaskets. I picked up some black gasket material, in a roll, at Pep Boys (by the gasket sealant tubes) for $3. Then I used an Xact-o knife, a punch to cut new gaskets, using the old ones as a template.
The first time I did this, I bought the Fel-Pro "intake gasket set", which ran me $30. It had a lot in it:
intake-manifold-to-head gaskets
small tube of RTV for the "china wall" intake manifold area
valve cover gaskets (cork)
middle-plenum-to-intake-manifold gasket
upper-to-middle-plenum gaskets
TB gaskets (tb-to-plenum, egr-to-tb)
The $3 roll of gasket material is a much better deal!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 7, 2001 | 01:06 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
If your running K&N filter you will get a lot of that, due to the poor Micron filtration rating of a K&N. Thats why K&N filters flow more air, less filtration. Also means shorter engine life.
If you don't believe and you want to put me down, JUST GO COMPARE Micron ratings. It will shut you up real fast.
And one last thing, you know that 5HP they promise, you don't get it till the HIGH END.
LOL
Old Nov 7, 2001 | 09:06 PM
michael's Avatar
Car: 1991 Formula
Well my K&ns got sold I didn;t likde them and realy didn't trust them with the cut air boxes. Would the air boxes have anything to do with the gunk. I Looked at autozone in the Chilton manual for the intake **** It says to drain the radiator is that nesesary?/ or do I just unbolt everything and clean the **** outa it and put it back together I was hoping some ppl would have pics of this :-(
Old Nov 7, 2001 | 11:09 PM
86BIRD-MY FIRST CAR's Avatar
The best stuff is GUMOUT AIR INTAKE & THROTTLE BODY CLEANER. this stuff is awesome, you will notice the difference.
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Nov 8, 2001 | 12:15 AM
87_Camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86BIRD-MY FIRST CAR:
</font>
i had to get the stp stuff.
Old Nov 8, 2001 | 09:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Michael, the section you read probably talked about taking off the intake manifold. The upper radiator hose (follow it to the engine) goes into a thermostat "water neck", which bolts to the intake manifold. So if you pull the intake manifold, you'd need to drain the radiator.. but we're just talking about the upper plenum (spider looking thing) and throttle body.
Old Nov 8, 2001 | 07:28 PM
michael's Avatar
Car: 1991 Formula
Well the pics in the chiltons manual didn't show any pics of the intake manifold they just showed pics of the intake itself so idunno haha how much of a pain does it lead to to do this task? anyway
Old Nov 8, 2001 | 07:29 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
As far as K&N filters having poor micron ratings that could be true, but how high do you want that rating really? I mean you don't want to have it so high you choke your engine of air. K&N also says on their filters that dust and dirt works to your advantage, perhaps it blocks more dirt that you claim gets by. I highly doubt that many people would buy K&N solely on the promised 5hp gain, I know I didn't. I liked the fact I didn't have to buy a new pair of air filters every time I needed them.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Nov 9, 2001 | 12:17 AM
breathment's Avatar
thats why you OIL the filters, without it, then yes they do suck at filtration, the OIL helps to catch the crap.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
Old Nov 9, 2001 | 12:19 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Don't worry 87_Camaro, the STP stuff works great, I just did an IAC passageway cleaning w/ it and its perfectly clean now.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
