Hook n Go ! :-)~
Hook n Go ! :-)~
What else would I need besides a posi rearend to do this swap ? Can these parts be found in the boneyard ? If so how much have you guys paid for them ? Thanx guys
Wayne
Car: 1986 Firebird
Engine: 2.8 V6
If you buy a rear axle with drum brakes, you don't have to do anything else. Make sure to replace the body-to-axle brake hose, and it might be a good idea to replace the e-brake cables while you're under there.
If you buy a rear axle with discs, there's more stuff. Try to avoid an 82-83 rear disc axle. Those were the only years of f-bodies that used SAE fittings; 84-2001 use metric fittings. If it's an 82-88, you should take the master cylinder. For all years, take the proportioning valve. Seems in '84, the front-to-rear steel brake line entered the prop valve in the front. Seems after that, the front-to-rear line entered the prop valve from the bottom. When I did the swap, instead of trying to bend my "bottom-entering" brake line to the front, I took the whole front-to-rear brake line from the '84 parts car. If you want to save yourself from that hell, you can also buy a prop valve from GM for your year of car.
If you buy an 84-88 rear disc axle, be prepared to rebuild the rear calipers with GM's recall kit. 89-92 rear calipers are a better design.
Oh- drum brakes = J50. 82-88 discs = J65 option code.
The master cylinder difference was only from 84-88. In 1989, GM used the original "disc/drum" J50 master cylinder for both disc/drum & 4-wheel-disc systems.
There was a service bulletin from GM about the master cylinder differences from 84-88. It was found out on the Suspension board (I forget the guy's name, I'll dig it up). The bulletin said how some customers from 84-88 were complaining about excessive pedal effort with their 4-wheel-disc systems. These weaklings
wanted an easier brake pedal.
GM said that the J65 master cylinder was designed to improve pedal "feel" usually desired by performance drivers. They then said that the J50 master cylinder could be installed without problems to give an easier pedal. The master cylinder swap was the hardest part of my job (I bought a rebuilt, tried for a week to bleed it, took it back for another one, and that one worked perfectly), so I'd say, if you don't have to swap the m/c, don't.
-Tom P (Hot rodded 1986 Firebird 2.8l)
[This message has been edited by TomP (edited November 08, 2001).]
wanted an easier brake pedal.GM said that the J65 master cylinder was designed to improve pedal "feel" usually desired by performance drivers. They then said that the J50 master cylinder could be installed without problems to give an easier pedal. The master cylinder swap was the hardest part of my job (I bought a rebuilt, tried for a week to bleed it, took it back for another one, and that one worked perfectly), so I'd say, if you don't have to swap the m/c, don't.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Thats fu(kn awesome
But I cant get it cus they dont sell them near me , and the company does not sell them to individuals
.There is a retailer in Louisiana , but its far away from me ....But thanx anyway .And thanx for your help guys . Wayne
.There is a retailer in Louisiana , but its far away from me ....But thanx anyway .And thanx for your help guys . Wayne Thread Starter
<font face="Verdana, Arial" size="2">Originally posted by WaynesRS:
Thats fu(kn awesome
.There is a retailer in Louisiana , but its far away from me ....But thanx anyway .And thanx for your help guys . Wayne </font>
Thats fu(kn awesome
. Right in Baton Rouge , where im at ! Trending Topics
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
wayne,
the ring and pinion (gearset) shouldnt cost too much i think they go for about $100
Slayer of the following:
1996 Riced-out Honda Civic (all show and no go!!!!!!)
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Newer Ford Explorer
Food that makes me sick: RICE
1991 Camaro RS 3.1 V6 5-speed
1991 Z28 Rims with Firestone Firehawks
dual snorkel intake w/ slashed boxes, 2 K&N's, 180* t-stat, 80 series Flowmaster (sounds AWESOME)
my motto: I CAN'T DRIVE 55
2000 saturn
1986 Camaro 2.8
Newer Ford Explorer
Z28/ZR1
Oct 23, 2015 01:04 PM
