86 CAMARO 2.8 HELP!
Old Nov 12, 2001 | 05:33 PM
onehotz's Avatar
86 CAMARO 2.8 HELP!
I have an 86 camaro 2.8 multipoint V6, it doesn't want to run it has new alternator,battery,pcv,spark plug wires, and semi-new plugs, also belts, it just cranks and cranks and cranks but doesn't want to turnover it sounds like it's about to but doesn't, all it's doing is cranking away and a few almost kicks to turnover but doesn't, I hope someone can HELP ME ASAP Thanks!!!!
[This message has been edited by onehotz (edited November 12, 2001).]
Old Nov 12, 2001 | 07:07 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Welcome to the boards,
check to see if your injectors are hooked up to their connectors.Do you hear the fuel lines pressureize,you should be able to hear the fuel pump come on when you turn the key.If you dont then check your fuse,if its ok then you probally have a bad fuel pump.Hope I helped some
[This message has been edited by 85SportCoupeto89RS (edited November 13, 2001).]
Old Nov 12, 2001 | 07:56 PM
KED85's Avatar
Fuel Pump.
Welcome to the club.
Mine is shot, it await funds for this project.
I'm looking at $400 so far.
All AC Delco stuff, tho & new FI hose.
May be going to a later model tank, for baffles lacking on my 1985.
Fuel pressure.
Find the Schrader valve, go get a fuel presure test gauge, screw in, turn on key.
See what the guage says. I get mine to read 10-ish (it's 45-50 for proper operation). Mine starts, Barely.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 13, 2001 | 10:01 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
85-up 2.8 = fuel injected
multiport = definately fuel injected
I think Ked's got the answer, but some other things to check:
spark
bad MAF sensor (unplug it, try to start car)
timing
TPS adjustment
EGR valve "stuck open" (feel underneath)
-Tom P (Hot rodded 1986 Firebird 2.8l)
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
BADNBLK
Nov 16, 2016 09:12 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
