Winter Storage
Old Nov 14, 2001 | 06:01 PM
Jaren Bon Jovi's Avatar
Winter Storage
I parked my car for the winter about 2 months ago for winter, usually I just clean it up and put a cover over it. I was watching this show and it said you should drain the oil and put new oil in it when in storage, does it really even matter?
Old Nov 14, 2001 | 08:35 PM
DeadHero8's Avatar
yes, this helps, also put it up on jackstands to help prevent dry rot
Old Nov 14, 2001 | 10:23 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
No reason at all to do jackstands. Things will rot whether the damn car is in the air or not!!
Also, jackstands on a third gen can be a shaky proposition. These cars have flexible chassis', and if it isn't perfect, you'll flex the unibody. There is NO reason to do jackstands unless the car is off the road for a VERY long period of time...not just a winter.
Also, I wouldn't drain the oil, as I like to start mine every 2-3 weeks, and let it run for 30 min or so and get real warm. Nothing's worse than not having your seals get lubricated properly for 4 months.
My advice is to park it in a garage with a cement floor, put down a plastic tarp to keep moisture away, cover it, fill the tank and add dry gas, and run it every couple weeks or so. Works for me
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 95k miles
-Hypertech chip, Accel 8.8MM wires and coil
-K&Ns with gutted airbox
-Alpine 60x4 with Boston 746s and RX97s
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 46k miles
-Xtant 403a 50x4 + 300x1 powering a 10" Eclipse Aluminum in a JL Stealth box, Boston RM6 fronts, Monsoon rears (temporary!!), Eclipse 5341R CD, All Monster's goodies...
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
PurelyPMD
May 5, 2016 04:57 PM
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
Formula8r89
Sep 22, 2015 04:24 PM
jerflash
Exterior Parts for Sale
Sep 22, 2015 09:58 AM
