???my rear end whats wrong with it???
Old Nov 13, 2001 | 06:02 PM
mybeamoflight's Avatar
I own a 92 camaro rs. its a v6. when I first got the car I was able to spin both of my wheels. I did something to it and now it spins one tire and it knocks. I asked other people about it and they told me I had a limited slip rear end. that doesn't explain the knocking! I want to fix it asap because im selling the car. please help!! I would like some tips on how to fix it in the cheapest way possible. thanks
Old Nov 13, 2001 | 06:37 PM
92_CamaroRS's Avatar
Does it knock or skip?
Old Nov 13, 2001 | 07:11 PM
Camaro_hunter_d's Avatar
Well if you spun the tires all the time, you probly broke something. The 10 bolt is not known for its strength. Other wise narrow down the "noise" knock, all the time while moving, varies with speed?
If it varies with speed you did break something. if its constant its probly a bearing or maybe a guide.
Old Nov 13, 2001 | 07:41 PM
SlowCamaro88SC's Avatar
tranny mount?
Old Nov 13, 2001 | 08:18 PM
I Cant Drive 55's Avatar
If it was a posi you may have broken an axle or stripped the splines on the end of the shaft.
just a guess.
Old Nov 13, 2001 | 10:01 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You defantily broke something in there.
Old Nov 13, 2001 | 10:46 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
same happened to me i currently have a broken trans mout i'm just hoping thas all...
"Work like you don't need the money, love like you've never been hurt, and dance like you do when nobody's watching."
Old Nov 14, 2001 | 04:40 PM
it knocks and only when i accelerate
Old Nov 14, 2001 | 05:36 PM
BitchinRS's Avatar
Does it do it when you accelerate hard or normal? If it happens only when you accelerate hard it's wheel hop. which is your rear end bouncing around. There's not much you can do for except add a few things to help reduce it. also replace your bushings with better ones.
If it happens all the time you torn or bent somthing back there. Do a physical inspection to see if it's any thing obvious.
Old Nov 14, 2001 | 11:32 PM
where the heck did you get posi?
Old Nov 15, 2001 | 09:10 AM
I bought it like that.
Old Nov 15, 2001 | 10:35 AM
KED85's Avatar
Tranny mount.
$10
Greasy dirty job.
40 minutes.
Hope you make profit selling car.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 15, 2001 | 01:02 PM
BitchinRS's Avatar
that posi unit must be an after market then. I don't think the 92's came with posi stock.
Old Nov 15, 2001 | 02:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Or, maybe the previous guy knew something about cars, and swapped in another f-body's axle?
The wheel hop noise might be made worse if it's beating the hell out of a worn-out shock! If the shocks are the original '92 units, replace them.. same with the front struts.
-Tom P (Hot rodded 1986 Firebird 2.8l)
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
