headers? which ones fit?
Old Oct 10, 2011 | 09:44 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iv been eyeballing some new ideas for my car to beef it up alittle and make it sound beefier so im tossing the idea around about headers. what headers fit our cars? can we use the stock y pipe? post links or pictures to what you have please!!
Old Oct 10, 2011 | 10:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: headers? which ones fit?
Search. And Pacesetter 70-1206.
Old Oct 11, 2011 | 08:53 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Check the sticky at the top about aftermarket parts for our cars, it lists the part numbers for headers in there. I also have Pacesetter headers/Y-pipe on mine.
Old Oct 11, 2011 | 12:29 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
These
http://www.summitracing.com/parts/PSM-70-1206/
Or the more expensive but nicer looking ceramic coated
http://www.summitracing.com/parts/PSM-72C1206/
Old Oct 11, 2011 | 05:36 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
does anyone know if the pacesetters add HP or not?
Old Oct 11, 2011 | 06:41 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Anything that improves flow should add some HP. How much exactly? Depends on what else you do.
Old Oct 11, 2011 | 06:45 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
complete valvetrain overhaul. agressive cam with magnum rockers (compcams) and I was comtemplating an underdrve pulley kit and a performance chip.
Old Oct 11, 2011 | 08:06 PM
Engine: L31 350
Are there any headers that we can keep and use our stock y pipes though? I just got my exhaust done a year ago and I'm about to put it back under the knife so I can get my cowboy duals on but I also want alittle better sound and the Umph but I wanna keep the stock y and the rest of my exhaust
Old Oct 12, 2011 | 12:45 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
The Y that comes with the headers is way better. More of a true Y instead of the T that's standard.
Old Oct 12, 2011 | 06:29 PM
drdave88's Avatar
Engine: 6.0L
The Pacesetter Y-pipe also is mandrel bent, which means there are no kinks in the bends.
Street Lethal
Apr 30, 2019 12:14 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Wvcamaro
Sep 4, 2015 08:38 PM
LilHot
Aug 23, 2015 09:36 PM
theurge
Aug 21, 2015 12:46 PM
