turbo or not to turbo
Old Nov 22, 2001 | 09:35 PM
85berlinetta19's Avatar
will any turbo work or does it have to be specific? also what mods would i have to do on the old 2.8? thanks in advance.
Old Nov 22, 2001 | 09:54 PM
Xenodrgn's Avatar
:sigh:
I'll start by saying one thing.. if you've got alotta beans to spend, Camaro_Hunter_D and Generation X Racing (his company) are going to develope a turbo kit for the 60* V6 sometime in the future. It will be a kit, with the understanding that a performance rebuild will be nessesary, he will offer a kit with and without an intercooler, and will also offer the tubing seprately (I'm pretty sure of this anyway)...
To answer your question, no, not any turbo will work. If it's too big, the amount of spool time and lag will be enormous, and you will loose alot, if you make it too small, you loose alot of potential there too.
The idea will be to get a turbo off of a car with similar internal engine dimentions... CI, CR, ect... and still have it be powerful and good enough to create some good boost (20 PSIG)... I don't know the applications out there, but they exist.
Next comes the exhaust routing and intake routing, again, do-able, but time consuming and money consuming!!!
The rebuild, more money...
Tuning expenses, things like fuel managment, spark management, wastegates and blow-offs, intercoolers... more money
Advantages: braggin rights, a hella strong top end, and maybe 100HP at the wheels
Power is directly proportional to money.
If you want power quick and easy... get a 50-75 shot of nitrous... a good running engine will take it, and you get an instant boost whenever you want it.
Hope that sums it all up for you.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Nov 22, 2001 | 09:59 PM
Xenodrgn's Avatar
As far as engine mods for a turbo set up... you'd need a fuel management system, spark management system, forged innards, possible reduce CR... after that is all the obvious stuff... pipe routing and what-not.
Old Nov 22, 2001 | 11:00 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
In other words lots and lots of stuff to do.If your gonna do this your self then your lookin at some down time for your car.
[This message has been edited by 85SportCoupeto89RS (edited November 22, 2001).]
Old Nov 22, 2001 | 11:47 PM
Monkie's Avatar
Put it this way you are basically putting in a V8 engine. You will need all the parts, the same amount of time, and the same amount of power. It is up to you if you wanna try it.
Old Nov 23, 2001 | 04:12 PM
pontiac's Avatar
you can get 200hp+ out from 2.8 with single turbo setup. all you need is to take care of air/fuel ratio when boost is on (to verify it a/f monitor, spark reading, egt meter would be useful). you're not able to use big boost, but if i'd be driver of 2.8, i'd be happy with 200hp since car is not that heavy as V8's.
all you need is custom exhaust, turbo, 7th injector and its driver _or_ to replace 7th injector you need custom prom work.
here's one solution that budget turbo builder could use:
- turbo from 2.x ford/mopar (we're not looking for big boost)
- exhaust: DYI (flip stock exhaust and/or custom made)
- the 7th injector, cold start injector from audi,saab,vw. it sprays continously when activated
- driver for injector: pressure swich that will connect 7th inj. when boost is on for ex. 5psi
there's plenty of fiero guys running happy with turbos, so why don't you do the same?
-P
Old Nov 23, 2001 | 11:22 PM
Camaro_hunter_d's Avatar
<font face="Verdana, Arial" size="2">Originally posted by pontiac:
-P
</font>
Actually I was going to run 24Lb injectors. No need for 7th. Headers custom made, cause I want to keep everything under the hood like P/S and A/C. Though I was looking at a Straight T3 turbo, 19 PSI Max or around that. While doing the test trails on my car(Having a lap top record everything for about a month) so I know what to change and tweak in the comp chip. Adjust A/F, Spark, Detonation retard, MAP Retard, amonst other things. then try the final chips and keep it as a "Base line" controller chip.
After getting the intercooler installed and running more diagnostic with the lap top reconfigure the "Base" chip and distinguish the two parameters with and without the intercooler. Then boost untill something breaks. Sounds like fun. Raise the boost untill the engine requires TOO much octane to be on pump gas, or carefully record the info as I slowly raise the boost untill a rod, piston, or something else breaks and give the next lowest level sustained successfully as the max PSI to run. I expect to get it around 17-18 PSI and around 250-260 HP. Enough to be considered a threat, especially for a 2.8/3.1/3.4 add nos and be even more potent. I can't wait. MUUU HA HAH HA
Old Nov 24, 2001 | 06:38 AM
pontiac's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
</font>
wow! you're actually doing it
bigger injectors and custom prom work is much better than the one i suggested. you can fine tune all the parameters.
do you have EGT and air/fuel meter installed? cast pistons will melt in no time under big boost if something goes wrong
good luck with turbo!
-P
Old Nov 24, 2001 | 11:36 AM
Well I have the A/F ratio already. I am now getting the Fuel Pressure guage. When it comes closer to this happening I am getting the full compliment of guages, EGT, Oil Pressure, Oil temp, oil coolers ect. I have a long way to go before I can even start this project. But I have the majority of the tools and equipment alreay so I am alot closer then the one time builder.
As I said before my biggest thing I want to do is get the turbo set up while keeping everything under the hood. I am going to convert the fuel system to an out of tank pump and add a few more filters an possibly a fuel cooler. I know the patch cord to the diag plug can be made I found directions for it somewhere, I just need the live running program so I can adjust on the fly.
The biggest problem I am still having is where to route the down pipe. I really do not want to run it under the K frame. I have a few Ideas, but untill I start I'm not sure where its going.
Old Nov 25, 2001 | 06:32 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
If your going to do a Turbo, you might as well get another 2.8, and start to rebild it. Cause the one in your car isn;t going to handle it. Then once you have it built up, you can turbo it
Old Nov 25, 2001 | 06:44 PM
<font face="Verdana, Arial" size="2">Originally posted by Joe_L:
If your going to do a Turbo, you might as well get another 2.8, and start to rebild it. Cause the one in your car isn;t going to handle it. Then once you have it built up, you can turbo it</font>
Actually I plan on doing this with completely stock internals(which most of us have). If I am going to build an engine up its gonna be the 4.3 Turbo Cyclone to swap in after its done. And I have a 3.1, but its the same as the 2.8 so... I plan on doing this about the same time I start doing the 4.3 So I can use the same turbo and other componets. I know the turbo will be a little big for the 3.1 but I'm not going to buy 2 turbo's and only really be needing 1.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
