y-pipe
Old Nov 26, 2001 | 05:23 AM
camaro84boy's Avatar
y-pipe
You guys out there with the 2.8 or other model of engine, do you have an annoying y-pipe that sticks out underneath your car? When I mean sticking out I mean If you went over a speed bump first thing to scrape would be that darn y-pipe. Usually on the passenger side it sits low. On berlinettas I have seen it too. Not sure what other models, But I have it on my 2.8 v6 automatic 84 and it bugs me. Anyone out there know of a solution or an aftermarket y-pipe that eliminates the problem, that is for my specifications or do I just have to suffer?
Old Nov 26, 2001 | 09:25 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
When i had my flowmaster, the exhaust sat lower and I scraped the cat on EVERYTHING. When i went back to a stock muffler, it stopped scraping. Do you have an aftermarket muffler?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-*Slowly* collecting parts for T5 swap
Old Nov 26, 2001 | 10:59 AM
KED85's Avatar
Gale Banks makes the pipes (Y)
So does Edelbrock.
Applications are for V-8!
Modify it!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 26, 2001 | 02:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My AP y-pipe is a bit lower than stock; but I've never scraped it on anything... I'll see if I can measure how low it hangs (from the bottom of the fender) tonight for ya.
By the way, if you're missing the rear hanger for the catalytic convertor, the whole y-pipe can "hinge" on the manifold bolts. Your system might be buckled in the middle, and the weight is tilting the y-pipe down. Our y-pipe inlets are only held to each manifold by two bolts, so the y-pipe outlet can "rock" up and down from the floorboards.
-Tom P (Hot rodded 1986 Firebird 2.8l)
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
