Oil Leak
Old Dec 9, 2001 | 06:08 PM
I_Live_4_my_RS!!!'s Avatar
Oil Leak
Hey guys,
Well, I've developed a decent oil leak. Yesterday I notcied a good bit of oil on my driveway and decided to put it up on a jack to inspect the underside... I received a horrifying image, Oil sprayed all over the underside of my car back to the muffler and all over the pipeing. It looks like the oil is coming from were the oilpan and the transmission meet. I'm not sure if maybe it is a gasket or what. The question is... WHAT DO I DO?
1992 RS 3.1
Home Built CAI
Flowmaster 80 with custom 2.5" pipes and 3" stainless steel tips
+no cat
Kills,
Mitsubishi Eclipse (he grinded some serious gears!)
Various pickup trucks
3000GT
1991 RS Camaro
and, the gran finale
A Geo Metro! WOOHOO
Old Dec 9, 2001 | 06:44 PM
89BlackBirdKid's Avatar
That sounds like it my be your rear main seal that went out.
Josh
1989 Firebird
Working the 2.8 to 3.4 swap with a 5 speed.
Kills: 2000 Silverado V6, 1995 v6 mustang, 1994 rodeo v6, 2001 Ford Sport trac, 1992 honda prelude riced out
Losses: 89 GTA, 95 Z28, 90 Camaro 305 TBI with mods
Old Dec 9, 2001 | 06:47 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Welp, it could be the Distribtor O-ring, The rear main seal, or the oil pan gasket.
You can look and see if the distributor o-ring is leaking......but the rear main seal and the pan gasket would require the removal of the tranny to see/replace.
Keep an eye on the oil level....dunno what else to tell you. If it's leaking badly you'll need it fixed soon.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-*Slowly* collecting parts for T5 swap
Old Dec 9, 2001 | 06:53 PM
KED85's Avatar
If you are ready to tackle that job, it's messy, but very rewarding. You can also rebuild your distributor at the same time & get back ALOT of pep your car has lost over the years.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Dec 9, 2001 | 09:54 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
It could also be your valve covers. If one of them is leaking it could be running down the side of the block and onto the trans. inspection cover and the oil can also be blowing back over the undercarriage as you are driving,
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Old Dec 9, 2001 | 10:58 PM
I looked under the hood and everything is looking good there, no leaks at the head and it is obvious that it has been leaking while I've been driving. I havn't been getting a smell of berning oil in the car so I doubt that it has been dripping down the side of the engine and onto the tranny. The oil level went from right on the top of operating level to right in the middle almost overnight! In other words... my car is not going to be driven untill I get this fixed. I am one sad fellow.
Old Dec 10, 2001 | 12:33 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Distributor O-ring leak. Details are here.
https://www.thirdgen.org/messgboard/...ML/000888.html
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
<font face="Verdana, Arial" size="2">Originally posted by FAST RS:
Im all DAMN all in mini skirts. They had 4 sitting across 1 lying down and anothe rsitting on the girl hat was lying down. IT was Sweet when i got to practice one of my frineds was counting how many girls were comming out of my car.</font>
Old Dec 10, 2001 | 01:50 PM
BitchinRS's Avatar
The leak from the distributor can be verry hard see. Your first step is to find out ware the oil is comming from. Get a small flash light and go over the engine from front to back, top to bottom. Also you may want to double check your oil drain plug. It sounds kinda stupid, but the last time I had that much oil under my car thats ware the leak was comming from.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
