Car got stuck in second gear while driving..YIKES
Old Dec 11, 2001 | 04:37 PM
86BIRD-MY FIRST CAR's Avatar
im driving along and i come to a stop light so i apply the brakes and the car was stuck in second reading at 2500 RPM'S,i could barley stop the car and heading into onward traffic. so the only thing i could do was stick the car in neutral and the RPM's went racing up to 8 and then stuck the car back in drive. car jerked forward very hard and roughly but went back to normal. and this happened TWICE in the same day. what happened??
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
[This message has been edited by 86BIRD-MY FIRST CAR (edited December 11, 2001).]
Old Dec 11, 2001 | 04:53 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Do you have cruise control? If you do, I would put money down that it's getting stuck... check the cable or disconnect it entirely. Could also be problem with the throttle cable.
Old Dec 11, 2001 | 06:12 PM
no i dont have cruise control, and how does the TB cable get stuck, if it is that how do u fx it?
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 11, 2001 | 08:16 PM
Xenodrgn's Avatar
next time, push the clutch in at the same time you SHUT THE THING DOWN! redline is like 6 or 6.5... 8 = valve float for sure... your engine won't last too long while a few more shots like that.
As for what's happening? Make sure the throttle isn't getting stuck... YOu may laugh, but if your floormat gets pushed too far down it won't let the pedal come back, and it'll get stuck.
Check for vacuum leaks, and other cables that could be getting stuck.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Dec 12, 2001 | 12:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
... YOu may laugh, but if your floormat gets pushed too far down it won't let the pedal come back, and it'll get stuck.</font>
Oh hell yeah! That damn thing happened to me once; I slowed at a stop sign, and was leaning on the brakes as my engine rpm's were way up. Nobody was around, so I sat there, panicked, wondering what was wrong- till I reached down and pulled the floormat away from the gas pedal- and the car acted normal again! Scary...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Dec 12, 2001 | 10:44 AM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Floormat thing happened to me too..
2.8 mpfi
My only mod: Flowmaster 40 series
http://www.geocities.com/pita_j2000/MyFirebird.html?1002261961590
PICS ARE UP!!
Old Dec 12, 2001 | 11:42 AM
Did i mention my car is an automatic so i dont think its the clutch thing and as for the carpet i removed it 2 days ago so it couldn't be the carpet either. still confused and scared to drive my bird..
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 12, 2001 | 02:13 PM
BitchinRS's Avatar
Pump the gas pedel a couple of times with your hand (with the car off) and see if it is sticking. If it is spary a little WD40 ware the pedel arm goes through the floor board to try and free it up. If that doesn't work make sure the linkage under the hood is not sticking.
Old Dec 12, 2001 | 02:15 PM
BitchinRS's Avatar
Of course it could be IAC is dirty as hell and it is getting stuck. Also could be your TPS going south or out of adjustment. I seen cars with a TPS just sit there and rev up and down like a cat on crack.
Old Dec 12, 2001 | 10:48 PM
Stupid question, but where is the IAC and TPS?. and how do u change the IAC or tell if it is dirty, and id it is the TPS how can i change pr adjust that. The car is a MPFI V6.
this is my first car so im kinda lost....
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 12, 2001 | 11:53 PM
BitchinRS's Avatar
There is a tech article on how to adjust both them.
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
As far as cleaning them I think it was TomP or Ked85 who had a really good explination on how to clean the IAC passage.
Old Dec 13, 2001 | 09:15 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I have had problems like this one was with the floor mat...but you already stated taht wasn't it.
But the other one was my throttle cable some how got a kink in it and it stuck in once while driving... Another things is get something better than WD-40, like Rust Check spray or something, and spray the cables under the hood and work them back and forth a couple of minutes then spray them again To make sure there free. If it still does this wide open throttle thing then get TomP or Ked to tell you about cleaning the IAC and testing the TPS.
Old Dec 13, 2001 | 10:17 AM
KED85's Avatar
Tom is primo on the cleaning & resetting tips.
Me?
IF STUCK, that's kinda easy to find.
Just follow the throttle cables.
IF it's vacuum you can hear that, too.
If electrical, download the codes.
Ain't it fun to search for those things?
Slam into neutral and shut off key as quick as possible.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Dec 13, 2001 | 11:08 AM
86Chicken's Avatar
I doubt that a messed up IAC or TPS would cause the car to redline. The IAC passages are not large enough to let that much air in. It would be like running a marathon while breathing thru a c<X>ocktail straw.
The TPS only tells the computer how far you have the throttle open. If it gets messed up and tells the computer that the pedal is floored and it is not, the throttle blades will be closed and there will not be enough air for all the fuel and the engine will probably stall or at least try to. (Back to the straw analogy)
I would look for something sticking. Maybe give everything a good coat of lube and move the throttle a few hundred times to make sure it works.
BTW It is not a bad idea to clean/reset the IAC and TPS anyway as a matter of general maintenance.
Just my $0.02
Dale
1986 FireBird V6
[This message has been edited by 86Chicken (edited December 13, 2001).]
Old Dec 13, 2001 | 11:37 AM
thanks for all the input guys, i'll do what u guys reccomended. Glad it wasn't a tranny problem or something...
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
hectre13
Dec 11, 2023 08:14 AM
specialized
Jun 18, 2022 09:26 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
