3.1 problem rich exhaust!
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
Help
new oxygen sensor
buy map this http://www.ebay.com/itm/GM-1-Bar-Map...s_Gear&vxp=mtr
I buy pace headers v6!
No check engine!
How to test your problem?
Very black plugs!
sorry my english!
new oxygen sensor
No check engine!
Very black plugs!
sorry my english!
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 3.1 problem rich exhaust!
New stock o2 sensor? You may need to get a heated o2 sensor. You need to find out what the o2 is reading.
Check the grounds, esp. the ecm grounds.
Clean the maf sensor.
Do a fuel pressure & leak down test.
Is the engine running cool? You might have to do a coolant temp sensor resistence test.
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Did this problem occur before the headers were installed, or was it a direct result of that work?
Car: Camaro 1988
He has a MAP car, read his post.
You have never run the engine without the headers? Where is the O2 located? Is it welded into the headers, or farther down the tailpipe?
Car: Camaro 1988
My problam cold and hot engine!
O2 no work cold engine!
I SWAP 3.1
where I could connect something wrong
I SWAP 3.1
Car: Camaro 1988
I have a manual transmission t5
Engine and ESM with an automatic transmission 700r4 car in!
knock sensor I connected directly to your ESM.
I check ecm grounds oK!
And more
When the engine is hot it stalls.
And more
Engine: 3.8, 3.4
Still not clear on whether or not this problem existed before the new headers or not.
If this problem was caused by the header install, then it seems like you need to get a heated o2 sensor.
