Adjustable Fuel Pressure Regulator
Old Nov 16, 2011 | 11:39 AM
85irocinjected's Avatar
Car: 1991 RS
I was reading about modifying the stock TBI fuel pressure regulator to be adjustable and wondered if the '91 3.1 MPFI fuel pressure regulator was the same? Can I do the same thing to it?
Old Nov 16, 2011 | 04:07 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Adjustable Fuel Pressure Regulator
You can put a penny under the diaphragm, but unless you have mods what's the point..
Old Nov 16, 2011 | 04:20 PM
Car: 1991 RS
Cause the car is running pretty fat and I figured if I can do that same mod I can dial it in to where it needs to be (factory psi) instead of spending the money to buy a new stock one or aftermarket for that matter. Just want this engine to last and run well 'till the spring and I don't want to put to much money into it. Already did a complete tune up including o2 sensor and she still runs fat. If I could get away with a "free" afpr then its well worth it. Otherwise I guess I will just shell out the cash for a stocker thats only going to be used for a few months. Seems like a waste.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
