2.8 issues
Old Nov 27, 2011 | 09:48 PM
fireredbird86's Avatar
2.8 issues
i just bought an 86 bird and i just did plugs wires and oil change. before i did that it drove fine until to day. i had stopped at a stop sign then hit the gas and had no power got home let it sit for a little bit then drove it again was fine until i stopped again does any one have an idea what may be causing this dillemma for now its my daily driver until i get another vehicle and im just wondering if anyone has a solution and or suggestions on what i can do to fix my problem thanks
Old Nov 28, 2011 | 06:17 PM
ex-x-fire's Avatar
Re: 2.8 issues
Test the fuel pressure, the test port is near the distibutor, spec is 36-45psi. You can rent a tester at autozone.
Test for spark, could be an ignition module heating up & acting up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
