valve stem seals?
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
valve stem seals?
Im not putting my heads back together for a bit but, I know when i removed all the valves the little black plastic seals all broke. They were so brittle and old.
Do i need to replace these with new ones? Which i would think i would.
Also are those seals made only for our valves or are they universal and fit all types of valves?
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: valve stem seals?
Fairly common size, and cheap too. Should be easily under $30 for a set.
Mine are going, but I'm way too lazy to tear apart the head for maintenance.
Car: 1991 Camaro RS
yea thats a long job if you just gotta take all that apart for just the seals..
Anyone happend to know the diameter of these seals?? size?
dpnt rep[lace them with stock o ring seals, goto ur local autoparts store and get a set of sbc stem seals. these go over the top of the valve guide and are 1000000 times better
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Valve Stem Seal 11/32"...
Car: 1991 Camaro RS
OK thanks. ill get them ordered!
Car: 1991 Camaro RS
get the umbrella seals those are what i was talking about just be aware there are different ones for the ex side vs the intake side since the ex side gets hotter. just order a set for a sbc and u will get the right ones
Car: 1991 Camaro RS
Car: 1991 Camaro RS
http://www.jegs.com/i/Fel+Pro/375/SS72527/10002/-1
will these do the job.. i live near jegs and summit.. lucky me.. so i figured id stop by and get them.
http://www.jegs.com/i/Comp+Cams/249/518-12/10002/-1
get that set then there is enough for the intake and ex , with those u dont need the o-rings, the o-rings are worthless anyway and they make reassembling the valve keepers and locks a pita
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I have a set of replacement springs still in boxes if you still need a set...
Car: 1991 Camaro RS
Well napa is stupid beacuse i ordered all the gaskets i needed, and unbrella valve seals for a SBC and what did they give me....those stupid o-ring ones.. Well i just need to keep my patients. I was hoping to have the motor back together this weekend to break the cam in but i guess itll have to wait a few more days.
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
I need to replace the valve stem seal on my 89 lb9 motor does anyone have a acutal part numbers for the intake and exhaust from summit or autozone?
I'm looking for the umbrella seals that dont require install of any o-rings.Do I have to use positive seals?any worries about valve guide not getting lube with umbrella type.I keep getting confliting fits wont fit on diff websites looking for felpro preferably thanks
ur local parts store will stock them , i preffer getting good quality ones from jegs or summit racing , but parts store ones will work just fine . i ust get the better ones since the turbo motor puts out a bunch more heat into the ex valves
no issues on the v6 witht he positive type seals either
this set is perfect for the v6 http://www.jegs.com/i/Comp+Cams/249/518-12/10002/-1
Car: 1991 Pontiac GTA
Engine: 5.7L TPI
Transmission: Built 700r4 w/2000 stall
Axle/Gears: BW 9bolt with 3.27s
So the heads have to come off or can i pull the covers, rockers, etc and find a way to keep air in the cylinder so the valves dont drop in? I got 150k on my 5.7tpi and cant afford a rebuild, but getting a bunch of oil into chamber when she sits. Hard to start and blows smoke. My father, mechanic for almost 40yrs, says its the valve seals. I dont wanna open another can of worms by taking heads off. Especially since previous owner booger the intake in.
Car: 1991 Camaro RS
Another resurrected post.... lol I started it in 2011 when my car was a slow 140hp turd... and the last post was about 1 1/2 years ago....
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Car: 1991 Camaro RS
355tpipickup
Sep 13, 2015 11:35 PM
