MAF Sensor questions.
Old Dec 9, 2011 | 10:47 PM
crazybird's Avatar
Car: 1987 firebird
I have a 1987 2.8. The car was stalling and I unplugged the maf and now the car runs better than ever. I have two questions.
1. Can I just delete the whole maf circuit?
2. what exactly happens when the maf is unplugged? like what does the ecm see?
Old Dec 10, 2011 | 08:35 AM
ex-x-fire's Avatar
Re: MAF Sensor questions.
The maf tells the ecm the density of the in coming air, so something is causing it to tell the ecm false info.
If you don't have a maf, it'll never run right. When its unplugged, it goes into limp mode, alot of fixed parameters.
Any codes?
Old Dec 11, 2011 | 03:34 AM
crazybird's Avatar
Car: 1987 firebird
ok do you know exactly what limp home mode is? i mean is there anywhere i can go to find out what values are involved in this limp home mode? i swear my car runs fine.
Old Dec 11, 2011 | 08:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Best thing to do is replace the MAF. No, you can't delete it. Only way to switch to a MAP is to swap harnesses and ECM's with a 90-92 car, and I advise against doing so due to problems with the ignition in the 90-92 harnesses.
DO NOT GET A CHEAP PARTS STORE MAF UNLESS YOU PLAN ON REPLACING IT IN A YEAR OR SO. The Delco ones WILL cost more, but there are differences in sensor construction that make this NECESSARY.
BumpaD82
Feb 26, 2016 02:57 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
sleprock
Oct 1, 2015 09:39 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
