Are these valve covers ok????
Old Dec 30, 2011 | 08:25 PM
SpecialEditon84's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: Pontiac 2.8 L V6
Transmission: Automatic 4spd
Axle/Gears: Stock
I own a 1984 Firebird and now has a rebuilt V6 trying to gave gold and chrome theme. Will these valve covers fit???? (2.8l)
Attached Thumbnails Are these valve covers ok????-snapshot-10-.jpg   Are these valve covers ok????-snapshot-9-.jpg
Old Dec 30, 2011 | 08:35 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Are these valve covers ok????
Id say they look right... what are they off of? I know mine have another hole in the covers for the PCV valve on the drivers side but mines a 1991 so it might be different. Im sure someone on here will chime in with a more definite answer.
Axle/Gears: Stock
or should i just keep the ones that are on it and sandblast to the bare metal and clear coat?
Old Dec 30, 2011 | 08:36 PM
Axle/Gears: Stock
well thanks bud well appreciated. I got them at a swap meet lol and they said they were for a V6 so idk. like mines an 84 so I don't know. I dont wanna rip them off and then be like durr, yah know?
Old Dec 30, 2011 | 08:46 PM
fasteddi's Avatar
Car: 1991 Camaro RS
not the best pic but heres what mine look like.....
Old Dec 30, 2011 | 08:52 PM
Axle/Gears: Stock
See like....hm. Are the camaro 3.1 and the firebird 2.8 same valve cover size???? like those are really square, no? and mine only have one hole on each side. so i dont even know.... could i drill holes??? prob not right?
Old Dec 30, 2011 | 09:09 PM
fasteddi's Avatar
Car: 1991 Camaro RS
3.1L and 2.8L covers are the same dimentions on camaros from what i remember. Do some searching. type anything you wana search on google search site and add thirdgen after the key words becasue I've had better luck with google then this sites search engine.
Cant you go see if your original ones on the motor have the extra hole?? Im not sure if your pre 1985 2.8L had one. The third hole is for the PCV(positive crankcase ventalation) valve
Old Dec 30, 2011 | 09:12 PM
fasteddi's Avatar
Car: 1991 Camaro RS
read this
https://www.thirdgen.org/forums/v6/6...-question.html
Old Dec 30, 2011 | 09:25 PM
Axle/Gears: Stock
Im pretty sure there are two holes on one valve cover and there are one on the other. but im not positive. i need to check tommorow.
Old Dec 31, 2011 | 02:37 AM
project89's Avatar
they apear to be the correct valve covers for a 2.8/3.1/3.4, if it was for a 3.8 or a 4.3 they wouldnt have the holes on the ends
Old Jan 1, 2012 | 12:37 PM
Axle/Gears: Stock
So your telling me that these would fit and I wouldnt have a problem getting them on and off???? AND my car would run right?
Old Jan 1, 2012 | 03:37 PM
project89's Avatar
valve covers wont make ur car not run right as long as there is a place for the pcv valve.
its hard to tell from the pics if they are correct for the motor so u will just have to pull one of ur stockers off and match them up
Old Jan 1, 2012 | 04:47 PM
Axle/Gears: Stock
ok so heres whats up. I got a PCV valve and an oil filler cap on the side of the driver and a vaccum hose that connects to the air filter on the passenger side. Can i drill an oil filler hole? or idk what to do?
Old Jan 1, 2012 | 04:54 PM
Axle/Gears: Stock
OR WAIT!! XD can i drill a hole for the oil filler cap and get an aftermarket oil filler cap??
Old Jan 1, 2012 | 05:49 PM
Axle/Gears: Stock
Hey, can you tell me how big the grommet is on the drivers side PCV valve?
Old Jan 1, 2012 | 06:00 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Give me a minuet ill go measure it....ill let ya know in like 10min
Old Jan 1, 2012 | 06:02 PM
Axle/Gears: Stock
k thanks man!
Old Jan 1, 2012 | 06:05 PM
Axle/Gears: Stock
and also can u measure how big the hole is for the grommet?
is the PCV valve the same on my car?
Old Jan 1, 2012 | 06:09 PM
fasteddi's Avatar
Car: 1991 Camaro RS
ok the size of the hole that the PCV goes into is 3/4 inch and my hole in the valve cover is 7/8 of and inch. Really you just need to find a groment that fits your PCV valve 3/4 inch and then make a hole in the valve cover so it fits in nice and tight.
its the same on both motors ... the size of the PCV
Old Jan 1, 2012 | 06:10 PM
Axle/Gears: Stock
ok the size of the hole that the PCV goes into is 3/4 inch and my hole in the valve cover is 7/8 of and inch. Really you just need to find a groment that fits your PCV valve and then make a hole in the valve cover so it fits in nice and tight.
OOOOh i see. ok. so how big of a drillbit do i need? persay
Old Jan 1, 2012 | 06:16 PM
Axle/Gears: Stock
oooh nvm i need a 7/8 drill-bit.
fasteddi's Avatar
Car: 1991 Camaro RS
well heres what i would do. Go to a auto store and take your PCV valve with you, ask them for a groment that will fit that PCV, it fits in there sorta tight but not like ya gotta jam it in there. Then measure the width of the outside of the groment you just bought. Dont add in the umbrellas on the groment into the diameter. You know what i mean?? Then find a drill bit close to that size.
Im thinking your gonna need a big bit though mabey one of those that have the circle on the out side and the bit in the middle?? You know the kind im talking about? I completly forgot what there called.
But your best just to drill the size of hole YOU need not what we have since youll be buying a different groomet then we have.
Old Jan 1, 2012 | 06:20 PM
Axle/Gears: Stock
oooooooh ok i see what your saying. My brother said that the chrome will flake off even if i drill a hole for the PCV. Im pretty sure it wont though if u cover the edges with a grommet, no? so I need a 1" ID x 1/4" OD oil filler grommet. and then I should tell the people at the parts store that I need to match the PCV valve with a grommet and find a drill bit that fits tight...correct?
Old Jan 1, 2012 | 06:27 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Well just try you hardest not to flake off the chrome when you drill it, use oil when drilling. Yes the grooment will help the chrome from flaking.
Mine dont have a grooment for the oil fill cap. My cap is just rubber and just fits in there.
But ya just find a grooment that fits your PCV and then find a drill bit of some sort that will drill the hole you grooment needs.
Axle/Gears: Stock
haha sorry im being so complicated. We can eliminate the PCV valve because I have my old one and its perfect so I can do all the measuring and bullshiat from there. Now I need an oil filler cap for said valve covers my brother said I need a 1" ID x 1/4" OD grommet for that and then find an oil filler cap to fit that. is that ok? or can i get like one that is stationary without the grommet?
Old Jan 1, 2012 | 06:35 PM
project89's Avatar
put masking tap were u are go9ing to drill this will stop it from flaking
Old Jan 1, 2012 | 06:37 PM
Axle/Gears: Stock
oooh thanks! good tip man!
Old Jan 1, 2012 | 06:45 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I got a starionary one thats stock on my car and looks good to me. Whats your stock covers have??
Old Jan 1, 2012 | 06:51 PM
ex-x-fire's Avatar
S/E84, are you putting those on a carbed 2.8L? If you are, from what I remember is that the driverside v. cover has the throttle brackets welded to it.
Old Jan 4, 2012 | 07:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I recommend a stepped bit and tape to keep from flaking.
I usually use these after I make a starter hole
http://www.harborfreight.com/3-piece...lls-91616.html
and yes I know harbor freight sucks but believe it or not these are awesome.
Old Jan 12, 2012 | 01:15 PM
Axle/Gears: Stock
what do you mean?
Axle/Gears: Stock
yeah i buy all my drill bits from there
Old Jan 12, 2012 | 01:16 PM
Axle/Gears: Stock
yeah im pretty sure they do. but do i really need them?
Old Jan 12, 2012 | 02:10 PM
Axle/Gears: Stock
will this fit a 7/8 hole? http://shop.advanceautoparts.com/web...GRPFILTAMS____
Old Jan 12, 2012 | 03:59 PM
Axle/Gears: Stock
or this one?
Old Jan 12, 2012 | 04:00 PM
Axle/Gears: Stock
Old Jan 12, 2012 | 04:04 PM
Axle/Gears: Stock
is your grommets OD 1-3/16"
Old Jan 12, 2012 | 06:21 PM
fasteddi's Avatar
Car: 1991 Camaro RS
It would make life alot easier to just take the PCV valve with you to autozone or whatever and tell them you need a grommet to fit that PCV.....
Old Jan 13, 2012 | 01:51 PM
Axle/Gears: Stock
haha im sorry im being difficult I just dont wanna spend money and have it be the wrong thing. yah know? I'm just afraid. my PCV is dry rotted and it wont come out of the grommet so i ripped it out.
Old Jan 13, 2012 | 02:16 PM
fasteddi's Avatar
Car: 1991 Camaro RS
If all else fails just buy a new PCV valve(there like 3 bucks) and then buy the grommet at the same place. Then youll know they both fit.
Old Jan 13, 2012 | 02:34 PM
Axle/Gears: Stock
alright know I know what to do. and after that i need a rubber oil filler cap or chrome to fit and then a gasket set for the valve covers! I'm on my way!
Old Jan 13, 2012 | 02:46 PM
  #42
fasteddi's Avatar
Car: 1991 Camaro RS
there ya go! have fun. Hope its warm there. Its like 15 degrees and 40 mph gusts here!
Old Jan 13, 2012 | 04:49 PM
  #43
Axle/Gears: Stock
hahaa its about the same bud
Old Jan 13, 2012 | 05:07 PM
  #44
fasteddi's Avatar
Car: 1991 Camaro RS
ahh just saw what state ya live in... ya winter suxs sometimes!!!
Old Jan 13, 2012 | 07:42 PM
  #45
Axle/Gears: Stock
haha sure does especially with a 3rd gen
Old Jan 19, 2012 | 06:41 PM
  #46
Axle/Gears: Stock
Ok guys latest update. I got my whole engine bay apart lmfao its such a pain in the arsss lol i had to drill out the brackets for the transmission and all tht shiat. Its all ready to go back on and now i have wireing problems -__- lolollol. I mean i can get it...just in time. but they are perfect! Il post pictures when its all done.
Old Jan 19, 2012 | 06:44 PM
  #47
fasteddi's Avatar
Car: 1991 Camaro RS
Good to hear!!!
Old Jan 19, 2012 | 06:45 PM
  #48
Axle/Gears: Stock
it looks mint.
Old Jan 19, 2012 | 06:53 PM
  #49
fasteddi's Avatar
Car: 1991 Camaro RS
Awsome, let us see some pictures when ya can, id like to see some chrome covers on a lil v6 for sure!!
Old Jan 20, 2012 | 03:57 PM
  #50
Axle/Gears: Stock
haha this lil V6 is gunna kick A$$. haha once i twin turbo it. its gunna be nasty.
