2.8 V6 Idle Speed Adjust
Old Jan 10, 2012 | 07:24 PM
Maroonz2800's Avatar
Car: 1987 camaro sport (Z28 interior)
Engine: V6, I6, V8, I4, I3
Transmission: auto w/OD, 5-speed, 6-speed
Axle/Gears: u/k
Can one adjust the idle speed on a 2.8 v6? it is the multi-port fuel injection. It seems to me that it idles a bit fast. Is it just a matter of adjustment?
Old Jan 10, 2012 | 07:30 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 V6 Idle Speed Adjust
What's the idle speed, both hot and cold? Should idle about 1200 cold, dropping to about 700 hot, under ECM control.
Old Jan 12, 2012 | 04:24 PM
Axle/Gears: u/k
yeah my car idles cold about 1600-1900 and hot about 1100-1300
Old Jan 12, 2012 | 05:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you are going by the stock tach, likely the tach is bad. See the sticky's on the top of the electronics board.
If that is a true RPM the IAC may be bad or there is a vacuum leak.
RBob.
Old Jan 12, 2012 | 05:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Check the adjustment on the TPS. The output voltage between the blue middle wire and the black wire should be .55VDC. Then go from there.
Old Jan 16, 2012 | 09:15 PM
Axle/Gears: u/k
alright thanks for the tips, hopefully i can straighten it out. and i'm going also by ear not just the tach, it even sounds fairly fast for an idle
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
rjcme
Sep 5, 2015 01:23 PM
86Base
Aug 8, 2015 01:34 PM
