Exhaust manifolds
Old Jan 13, 2012 | 11:22 PM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
Exhaust manifolds
Looks like I need a passenger side exhaust manifold (trying to correct a hack job from the PO) for the 3.1L V6 in my 1990 camaro. I was wondering, would an S-10 manifold work? Any help will be greatly appreciated.
Old Jan 14, 2012 | 09:05 AM
ex-x-fire's Avatar
Re: Exhaust manifolds
The s10 manifolds didn't have the egr tubing connection like the f bodys did.
Old Jan 14, 2012 | 05:49 PM
JTS's Avatar
JTS
Thanks. I knew I should have pulled that manifold when I saw it in the wrecking yard.
Old Jan 18, 2012 | 02:12 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Someone getting headers would probably sell you a set cheap, unfortunately I am pretty sure I threw mine out.
Old Jan 18, 2012 | 11:52 PM
JTS's Avatar
JTS
I'll start looking again once I have some extra cash. Can't really do anything to the car now anyways because it's under a foot of snow....all my projects are on hold till the snow melts. Thanks tho.
Old Jan 19, 2012 | 06:05 AM
ex-x-fire's Avatar
Look on the classified here, alot of guys swapped those motors out for 350s.
Old Jan 19, 2012 | 06:29 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Right here:
http://www.ebay.com/itm/350466045328...84.m1436.l2649
Comes with all gaskets and everything else necessary... Bolts with springs for the crossover pipe probably won't work, though. Not as cheap as a used one, but you never know what you're going to get with used...
Old Jan 19, 2012 | 08:30 PM
JTS's Avatar
JTS
Thanks! I still have to see how bad the PO screwed up the manifold. From what it sounds like he tried to replace the studs while it was still in the car. Needless to say there is a bad exhaust leak on the passenger side. Hopefully once all this snow melts out here I can check it out and see what really needs to be done.
Old Jan 19, 2012 | 08:35 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Best thing for it is to take it out and do it that way... Drilling those studs out on the passenger's side is a PITA on a GOOD day. But then you risk breaking the bolts...
On both of my manifolds, the studs were replaced (I didn't do it... Either the guy that dropped my engine in did or the PO of the JY car it came from did). And the ones that went in went into holes that were drilled ALL THE WAY THROUGH the flanges, so they kept loosening themselves right through the manifolds. I used 2 nuts on each stud and even that didn't work. I wish I had found this years ago so I could get a new one with an AIR plug (stupid AIR fitting kept coming loose as well and I don't have an AIR pump and never did have one). Only found driver's side manifolds for the longest time...
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
